Engloid »
https://forums.nicoclub.com/engloid-u11043.html
Thu Oct 16, 2003 8:43 am
I'm not trying to knock anybody or their work...
but you guys need to keep in mind that a warranty isn't everything. Odds are, the maker is only willing to repair the manifold if it cracks. Not that it's a bad thing, but by the time you pay shipping there and back, and add in the trouble of taking it off the car, putting it back on, and the downtime... I'd bet you guys would rather pay $50 for a part that wouldn't crack. Not that you can tell the future, but just reminding you that sometimes, the hassle of getting warranty work isn't worth saving a few bucks by letting a guarantee influence your decision. Buy what you think is most reliable, and do give weight to a person that backs his work, but don't make a guarantee your highest priority. Afterall...Craftsman has an excellent guarantee on their screwdrivers, but they're junk. Personally, I use them because the hassle and cost of downtime isn't bad.
As for the welding and cracking issues... There's a lot that's more important than having or not having braces. For example, the filler material in the weld is much more important. If it expands and contracts at a rate too much different from the base metal, a crack will prevail.
A suggestion to the maker... sometimes, a bigger weld isn't stronger. By putting more reinforcement on the weld, you also raise the angle at the toe (where weld meets base metal) of the weld. This increases the stress riser. A weld that is perfectly flush inside and out will be stronger than one with great reinforcement (all other variables the same).
It doesn't look like the crome is sticking to the welds very well. I don't know what can really be done about it, but I got a couple ideas you may try if you havn't. Maybe clean them with a scotch-brite wheel after welding, instead of a metal brush. or rig something to keep a longer trailing of gas coverage on the weld. or maybe travel faster and put less jules (heat energy) into the weld. Electropolishing may be a better option than chroming. It actually looks like it's been electropolished, but pics aren't always as good as seeing something in person.
Either way...I don't mean to sound negative, as it's great that you're doing these. It takes a lot of time and effort just to cut and fit one of these pieces together... and it's not something easy to duplicate. Overall, it's nice work and worthy of being proud of.
