Chris2.0SR wrote:So, again the question has to be asked. Any updates on this kit. April has come and gone. So has May. Hoping this kit is near completion. I could really go for some boost in my 2.0 Sentra.
silverarrow27 wrote:I'm thinking this is a dead project if Nissan confirms the new Versa does in fact will come with the DIG turbo engine in North America.
project isn't dead, its being worked on as we speak. patience
this was Versaspeeds update on another forum
Hey! Sorry I haven’t responded but if you guys have any questions you’ll get a quicker response if you just email me since I’m not on the boards that much.
Now, the reason for the delay as stated a few times before is this is all going to be done right and I’m not rushing it till everybody concerned gives it a “thumbs up” for production...I have three engineers checking each design (up to our fifth one)...things like harmonic distortions...stress points and more... it’s not as easy as putting on a few brackets and your done...the other thing we’ve been having problems with is room...there’s just not a whole lot of it and after some struggle we’ve decided that the AC lines will have to be relocated so another situation (after the brackets etc. Are given a green light) we will go after....I already have a company that can make a different setup but that will be the last hurdle....no engineers needed for the reroute.
There has been some mentioning of a Turbo setup as shown a few years back on the Fox Marketing Versa...there Versa was made up for the SEMA show (took them two weeks so you can imagine) and it was for show rather then a production setup.....just look at some pictures of the engine bay of the setup...there’s no air cleaner on the Turbo (no room) and they were only able to do a couple of passes with some really nice numbers because everything was set to the max and the motor would not have lasted if it was always at that setting and rumor was the performance was not good other wise...but as a show car it was impressive. Again, not as easy as it sounds (plumbing/room/ECU/BCM/ etc..
Now for the DC Headers....the original ETA was late May or sometime in June...so hang tight it will show up and unlike the OBX setup this will bolt on without any problems from a reputable company....again....done right!
So if you guys can just chill...let us do the job the right way....we’ll let you know (or email me) when we have the prototype in the Versa for testing and give you our opinion on it and some Dyno numbers....pestering will not speed it up....I’m going to do the project the right way and have no intention on rushing it and again as stated in other posts...everybody concerned is doing it as time permits for them.
That’s it! If you have more questions please email me and I’ll get back to you ASAP...I can’t give any ETA because it’s all predicated on when we get the engineering data back and everything works okay....the tubing/cooling and air intake is the easy part it’s the brackets and the load/positioning that has to be calculated properly.
