sanioll »
https://forums.nicoclub.com/sanioll-u18155.html
Thu May 19, 2005 6:07 pm
Quote »but you can't just get the flow rate...[/quote]you can and you will, get up your lazy *** and do stuff below:
1. first get a data logger and record rpm readings for couple of days while youre driving. set it to record rpm, let say every second.
2. take all that data, paste it into excel and find the average.
3. do not record data while the engine is idling, this will create a skewed normal distribution of graph towards the lower end. Simply record when youre driving. Dont leave it on, while the car is warming up.
4. now you know your average rpm that you usually drive at.
5. figure out the oil pressure that is coming out of turbo line, right before the tank at the average rpm you have found. Simply someone has to rev the engine let say at (your average rpm) 3000 rpm, and you have to take the measurement; easy as connecting your current oil pressure gauge to it.
6. now you know oil pressure at average RPM you usually drive.
7. BY HAVING TO KNOW OIL PRESSURE AT AVERAGE RPM AND DIAMETER OF TUBING THAT OIL GOES THRU, YOU CAN EASILY CALCULATE AVERAGE OIL FLOW THROUGH YOUR TURBO. THEN CHOOSING THE OIL PUMP IS EASY AS POINTING A FINGER AT THE STORE.
8. as for, what is the formula to find the flow rate of liquid thru the tube given the pressure; well do not worry about it, i will find it for ya.=====================================================
Just do the stuff above, and you may be able to make a revolution in turbo oil return for 240sx owners.
what do you say? you think you can do it? if you need any assistance in averaging, flow rate, any calculations, I do take all the responsibilty to help you out.
