The ultimate VH FAQ
Discuss topics related to the VH41DE, VH45DE, VK45DE, and VK56DE engines.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
This thread is created with the intention for people to contribute as much information as possible.
Theres a TON of information on NICO about this engine, wether or not its in the FSM or not... I got an email from someone this afternoon and thought that would be a fantastic idea... Id like to compile this information, and then we can do an article on it or something..... The KEY is here I want anyone to be as involved as possible.. Whatever tidbit that you have that is helpful.. I just dont want a bunch of stupid things like I HATE THE PLENUM or THEY WEDGED THIS ENGINE IN THE CAR... Lets try and keep this technical...
Things I dont want are things not related to the engine... THIS IS ABOUT THE VH45DE!
So ill try and start with some basic things that Ive picked up.... this is from the FSM.. So any other tidbits that arent from the FSM is good... BTW if this info is wrong please correct...
Closed deck engine6 bolt mains, 2 are crossed274.22CI, 4494CCBore/stroke- 93x82.7mm (3.66/3.256in)Multiport fuel injection with equal length runners370CC injectors2 compression piston rings1 oil piston ring10.2:1 Compression Ratio
Id like to see someone post a very accurate physical dimensions and weight...
EDIT: One other thing, if you have a technical question that isnt covered by this, much like what Rex is posting right below me, feel free to ask this so we can answer it.
Rex
Car: None
Are the injector top feed or side and are the low or high resistance, maybe even add the actual ohms??
Great thread idea BTW.
elwesso
2007 BMW M Coupe
Low resistance and side feed, 12-14ohms is the spec.
Raxephon
Car: '04 RX8...for the moment...
1991-1994: 8 individual cast aluminum intake manifolds, each feeding into dual ports. Each manifold has a cylinder number cast on one side which faces towards the valvecover when installed.
Intake manifold #8 also retains a side bracket that houses one of the fuel pressure regulators
Intake manifold to cylinder head bolts are 12mm, 2 per manifold(Length & thread pitch?)
Intake to Cylinder Head gasket is metal (Thickness?)
Modified by anlasak at 2:51 PM 10/6/2005
elwesso
2007 BMW M Coupe
They changed it in 94 to a single opening instead of the 2 openings.
Raxephon
Didn't they also swap the 8 manifolds out for a single intake manifold somewhere along the line?
elwesso
2007 BMW M Coupe
Not in the VH45, in the VH41 maybe.
PoorManQ45
good thread idea.
Can we get some internal specifications? Like clearances/tolerances
elwesso
2007 BMW M Coupe
Sure let me post up some of those later.....
Raxephon
zerothread?id=140310
1991 Q45 Timing Chain Links/Pins(May cover other years as well)
elwesso
2007 BMW M Coupe
thanks buddy!!! good info
Raxephon
I noticed this thread has fallen a little behind.
So, How much boost do you think the stock internals can handle if temperature is not a factor?
elwesso
2007 BMW M Coupe
All i can say is that Slim is running about 10lbs, and it has PROVEN to be reliable. he drove it for over 2 hours each way to come to NOPI..... took it on a large drifting session earlier this week and its all good... He has stock internals AND a stock ECU with only the JWT Boost ECU!
SO much torque on this that people say they can see the chassis flexing!
qsiguy
Car: 1994 Infiniti Q45 Turbo
I don't want to get off subject but who is this "Slim" that has a boosted Q? I'd like to get the specs and details on what he's done.
elwesso
2007 BMW M Coupe
He has a boosted VH45DE in a 93 nissan 300ZX
erbe
Car: 300zx, Q45
elwesso wrote:All i can say is that Slim is running about 10lbs, and it has PROVEN to be reliable. he drove it for over 2 hours each way to come to NOPI..... took it on a large drifting session earlier this week and its all good... He has stock internals AND a stock ECU with only the JWT Boost ECU!
10lbs???
elwesso
2007 BMW M Coupe
erbe wrote:10lbs???
erbe
Car: 300zx, Q45
How can I convert that to metric? Do you meen 10 psi?
elwesso
2007 BMW M Coupe
Yeah 10lbs.. as in .68bar.
PoorManQ45
elwesso wrote:Yeah 10lbs.. as in .68bar.
Wow, he's injecting a vacuum into his engine!
Actually it'd be 1.68bar wes. 1 bar equals outside pressure. You're thinking of a pressure gauge, not a barometer
elwesso
2007 BMW M Coupe
whatever.. its 10 PSI, anyone who doesnt understand that needs to..... well.. nevermind.
qsiguy
Actually elwesso is correct 10PSI equals .6894757 bar to be exact. 1.68 bar is 24.36634 PSI, that would be a lot of boost!
PoorManQ45
qsiguy wrote:Actually elwesso is correct 10PSI equals .6894757 bar to be exact. 1.68 bar is 24.36634 PSI, that would be a lot of boost!
Well, considering that at sea level 1 bar is atmospheric pressure.
anything under one bar is lower then atmospheric pressure, which by definition is a vacuum.
A "boost gauge" is actually a pressure gauge, not a barometer. When it says 0, it's 0 above atmospheric pressure.
Whereas a barometer starts out at 14.7PSI, which is equal to one bar.
So depending on how you look at it, we're both right, BUT sinse he said the word "bar" that implies barometer
*edit* You guys are confusing a pressure gauge with a barometer
24.36634psi - 10psi = 14.3psi, close to atmospheric
Raxephon
1 pound per square inch = 0.07031 kilo per square centimeter (1 kilo per square centimeter = 14.22282 pounds per square inch )
So it would be .70 ksc = 10 psi = .69 bar
elwesso
2007 BMW M Coupe
A-HA! I knew I was right.....
And the legend lives on! Wes>PMQ
Raxephon
psig = Pounds per Square Inch (Gauge) - (10)psia = Pounds per Square Inch (Absolute) - (24.7)
psia = psig + atmospheric pressure @ sea level (14.7psi)
I know Wes meant psig , which is what I wanted to know. But since this is supposed to be THE ULTIMATE FAQ on the VH45DE, I should have spelled it out more clearly.
Raxephon
'91 VH45DE cam tower bolts require a T-30 Torx bit.
(Clean out each bolt Prior to attempting removal !!)
I didn't get 1 completely clean & stripped out the bolt.
UK-SRi
Car: Nissan Cima 2007/2008
I thought that boost was usually specified as gauge pressure as opposed to absolute.
Mike
Raxephon
UK-SRi wrote:I thought that boost was usually specified as gauge pressure as opposed to absolute.
Mike
It is.
elwesso
2007 BMW M Coupe
OK since no one wanted to do this, I decided id go for it......
VH45DE camshaft angles
Nitrous and VH45DE
More camshaft information
A chain guide thread but lots of good information
Supercharged VH45DE in a skyline
VH45DE in a 240
More power related info
Return to “VH45DE / VK45DE / VK56DE Forum”
