The ultimate VH FAQ
Discuss topics related to the VH41DE, VH45DE, VK45DE, and VK56DE engines.
DRFTBLD
Car: 89 S13 VH45DETT
05 Ford F-150 Drift Support
91 S13 Tester
08 Ford Focus
Has anyone Seen or know of where a parts number list is for the VH. OEM replacement parts.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
what part numbers do you want.. I have the parts book and can look up anything you would need.
DRFTBLD
91 S13 Tester
08 Ford Focus
elwesso wrote:what part numbers do you want.. I have the parts book and can look up anything you would need.
Really everything.
Just looking for a guide, for everyone, for all OEM replacement parts.
This is what I have so far for the VH. Not a ton but just started.
Piston Rings:
Hastings ZM4892
Connecting Rod Bearings
Clevite CB-1655P
Therostat:
Nissan 21200-60U02
Oil Crank Seal:
Nissan 13510-60U00
Rear Oil Seal:
Nissan 12279-AD205
Water Pump:
Benk Arnley
Main Bearings:
Clevite MS-2060P
Thrust Washers:
Clevite TW-5975
Silfiniti15
Car: Nissan Silvia S15
I was just wondering if anyone could expalin or tell me the difference in the gasket sets for 90-93 and 94-96? Why is there two different sets, just tyring to figure out as i have a 95 vh45 and need new gaskets urgently and i cant seem to find the gaskets in nz. Only kit i can get is the 90-93 gasket kit. Any help appreciated! Just after a quick yeah they totally diff or nah mostly same otherwise ill have to try get something from overseas and get it shipped to me. Thanks in advance for any help :)
elwesso
2007 BMW M Coupe
Lower intake manifold gaskets will be different, 95 VH45 had valve cover gaskets where 90-93 did not.. So really all thats left are the upper manifold gaskets and stuff which are the same and oil pan gaskets, front and rear main seals which are all the same
Valve cover gaskets are going to be important for you to change as they do get leaky.
m280sxgt
Car: 1995 Nissan 240sx with AEM Short Ram Intake, KYB GR-2 Struts, Eibach Lowering Springs, HKS Hi-Power Exhaust
Was wondering if anyone could point me in the right direction. I am getting ready to do the VH s-chassis swap, and am going with the Mazworx goodies. I am looking for who could either fab new intake mani's, because hood clearence seems to be the common demoninator, or what hood is recommended to overcome this problem? I would prefer to do a dual intake setup like canadian drifter did on his project for two reasons no hood clearence issue and you get to keep the strut tower brace! I would outsource though as I am EPIC fail on the welding skills! My only concern I guess would be flow balance but I guess a crossover tube/tubes would help that.
BADA$$240
Car: 1990 240sx fastback five speed
I'm looking for bench flow results of the stock VH45de and stock VK45de heads? I've searched around but haven't really found much, at least no solid data.
spike thomas
elwesso wrote:They changed it in 94 to a single opening instead of the 2 openings.
So you're saying the 94 vh45 had one big intake port per cylinder instead of two? Do they split inside of the heads?
New Jersey
Car: 1997 Infiniti Q45
1990 Nissan 300ZX
i have a question in regards to injectors?
i know on Z32s the earlier style injectors cannot handle the higher ethanol gas we have today and crap out often. later Zs had injectors that solved this problem.
would a 1995 vh45de out of a usdm q45 have the updated injectors or the older style??
thanks, hadmt seen this answered yet.
New Jersey
1990 Nissan 300ZX
also, what iridium ngk would guys reccomend for a vh45de that will see some drifting in a z32 with an ecu from wes?
New Jersey
1990 Nissan 300ZX
nm i grabbed a set of NGK BKR5EIX-11
T04GTR
solid lifter conversion (using L series bits or hla with shims) for big revs with aggressive cams..
Return to “VH45DE / VK45DE / VK56DE Forum”
