The Qxxx4 needs more BOOM-diggity BAAAAyyyyAAAM!
Qxxx4
Car: 1999.5 Infiniti QX4
2012 Ford Mustang
your making alot of sense....
i tried messing with the wiring earlier today, including channels 3 and 4 and making sure polarities are right. i noticed it said bridged...i was confused.
channel 3 + - channel 4 + - and above 3/4 it says bridged
so do i just connect SUB1 + to ch3 +, SUB1 - to ch4 - ? and vice versa for sub2
i tried that it didnt work
looks like i gots more homework to do!!
Qxxx4
2012 Ford Mustang
i forgot to mention i tried doing everything with one sub with no luck. but i think im going to try to do this in series...
+terminal -> +sub 1 then sub1 - -> +sub2 then sub2 - -> -terminal
wouldnt that increase impedance?
Qxxx4
2012 Ford Mustang
here is how my subs came wired and how i figured would work.....
connected to the "subwoofer" 1500 w terminal.looks right to me, so what the heck! both my speakers are clarion 1051...pretty sure their 4 ohm each and are SVC (only saw two terminals on the speaker itself, not 4 which would make it DVC)
it looks like im pushing a 2 ohm load..meaning yes, probably not enough power to the subs....so ima figure out the best way to get a 4 ohm load from the subwoofer channel (1+ 1- terminal)
nnorton44
Car: 2001 QX4
I have yet to find a wiring diagram for a bridged 5-channel amp ill keep looking.
nnorton44
Car: 2001 QX4
Try wiring your subs to channel 5 also, I *think* the first four channels will be stereo and the fifth is intended for subs....
Qxxx4
2012 Ford Mustang
i tried everything.....including series/parallel to all channels and no luck.
the original owner emailed me to see how i like the subs/amp (i bought them all togehter from him) and said he had them working with the 1500w subwoofer channel conected in parallel to the subs. so. the amp/subs are not my problem. nor is power (measured 12.7V on the amp), nor is remote turn on (green light turns on and off with the deck), nor is subwoofer out on the deck or the connection between the two.
what the hell.
double check my ground maybe? i mean...i sanded down the freakin area...its bolted right on there nice and strong....
nnorton44
Car: 2001 QX4
If the amp powers then its grounded right
Empty V
Car: 2001 Infiniti QX4
1982 Chevy Corvette C3 Shark
You sure dude is telling the truth? I'd take it to a shop and have it tested, I'm sure they'll do of for around $20.
Good luck dude.
Qxxx4
2012 Ford Mustang
the guy was really honest, i doubt hed sell me a dead amp i mean i went to his house to get it, and he even emailed me after to see if i liked it....Maybe ill try it on my friends subs....ill isolate what the problem is and see whats wrong, maybe it IS the head unit which says its giving sub output but isnt
Adnan
Car: 2001 Pathfinder LE 4WD
damn ...i feel your frustration buddyone trick i would try to see if the subs are any goodis pressing on them down while you have the music playingif any of the subs start pumping as your pressing into them (lightly btw)they are more likely blown....i just hope its something wrong with the wiringi have no experience with 5 chan amps
Qxxx4
2012 Ford Mustang
theres a switch for "full" and "hpf"....either way i get nothing. tried the dials including turning the Low Pass Filter dial all the way up...still nothing. rca's are hooked up to right input too. argh. i dont know what else to do
Lars
Car: 1998 Pathfinder 5spd
Sounds like it is time for some additional testing. When you power up do the lights, etc on the amp come on? Do you have some other speaker hanging around you can use to test the output of the amp (hook up in place of the subs)? You bought another amp right? Try to hook the other amp up for testing and see what it does. Are you using some sort of low pass filter/crossover? If you are what are the settings on it?
nnorton44
Car: 2001 QX4
Id call a friend and try their amp
Qxxx4
2012 Ford Mustang
GOOD NEWS....hooked up amp to my psp.....headphone jack to rca's and the subs pounded like mad....so i tackled the head unit...tried line out rear instead of subwoofer out and THEY WORK!!!!!!! it sounds amazing, actually almost too much bass...almost. LOL I LOVE IT! thanks sooo much guys, expect pics and a video soon.....ima go wash my baby inside and out, do some finishing touches and GO FOR A DRIVE! thank you so much, everyone whether you posted or not, for reading, helping and all your advice, i couldnt be happier and i owe you all!!!
BOOM DIGGITY BAYYYAMMMM
now, time to experience the boomage.
ps......this means i did everything from start to finish all by myself.
ROGER....thank you so much for telling me where to run through the firewall, your photos on car domain which gave me an idea where to run the wire under the hood, and for lending me the freaking deck!
fueler, adnan, nnorton4, EmptyV, Lars, Snowsurflax, and anyone i forgot...you guys ROCK!
Empty V
Qxxx4 wrote:GOOD NEWS....hooked up amp to my psp.....headphone jack to rca's and the subs pounded like mad....so i tackled the head unit...tried line out rear instead of subwoofer out and THEY WORK!!!!!!! it sounds amazing, actually almost too much bass...almost. LOL I LOVE IT! thanks sooo much guys, expect pics and a video soon.....ima go wash my baby inside and out, do some finishing touches and GO FOR A DRIVE! thank you so much, everyone whether you posted or not, for reading, helping and all your advice, i couldnt be happier and i owe you all!!!
Glad it worked out dude, if you're going through the rear out you probably want to make sure you've got the low pass a-over on, no reason to send the entire spectrum to your subs they'll just get muddy.
Billy
Qxxx4
2012 Ford Mustang
yeah i got the LPF cranked all the way, it sounds great but im sure there is room for improvement. I was sitting in traffic just loving it. Its the perfect amount of bass, i get a good shake but my rearview mirror stays relatively in its place! YES! lol tommorow im going to make the wires a little neater and clean up all the speaker wire strands all over the place, and all the tools ive got everywhere, oh and install the dash kit (around the cd player)
Adnan
SWEEET...alright man..glad your happy and everything is working
nnorton44
Car: 2001 QX4
Lars
Glad you got it working! There is no better feeling than working your way through a tough problem and coming out the other end with exactly what you want!
Cheers to you!
