I've been there. But then when it's running right, it feels like it's all worth it.DoinkMobb wrote:So some Japanese dudes decided to put a 300 HP V8 in a large luxury sedan. OK fine, whatever.
But then they took a second look and decided that perhaps a vacuum line needed to be added, way back here where no human hand could possibly fit. And then another and another. And then they needed 40000 bolts to hold everything together under the hood. Why not engineer things in a such a way that something has to be destroyed, mangled and/or bent if you ever want to remove that item or another item in the immediate vicinity? I've never worked on such a convoluted, cramped and complex engine bay in my life.
It's like a Rube Goldberg design in there. It's insane. Fortunately, I have small feminine hands, but even so, I had no room to manuever. Everything is in it's own way. This car is a nightmare to work on. How was this thing put together at the factory? Did tiny elves assemble everything with tiny elf tools, all while Infiniti engineers are pointing at the engine, laughing heartily and saying "Man, can you imagine how pissed somebody will be if they ever attempt to work on this car themselves?!?!"
In case you are wondering why I now despise my Q45, it's because I removed the plenum. Take my advice: don't do it. Leave it alone. It's not for amateurs. While the plenum was off, I decided to change the sparkplugs and valve cover gaskets too. The sparkplugs weren't too bad, but the driver's side VC was just...annoying and aggravating. I was going to do the passenger side too, but thought "screw it, I'll do it at another time". And the knock sensors? No, I'm not doing those. Don't talk me into it, I'm not going to attempt it.
At this point, the sparkplugs have been replaced, the driver's side VC gasket is done, the throttle body, EGR, plenum and AAC have all been cleaned (still need to clean the MAF) and I've replaced as many hoses as I can reach. Hopefully tomorrow I can re-install the plenum and re-hook up the 11 million vacuum lines and coolant lines correctly.
I swear...I swear to those heartless, sadistic Infiniti engineers, that if my car doesn't start tomorrow, I'm pushing it into a swamp and leaving if for dead. Screw it. I'll go back to Subarus, cars that are designed to be user friendly enough to the average mechanic.
In conclusion, the Infiniti Q45 is a stupid car and I hate it.
Man, I've always been afraid to get a Subaru because of the horizontally opposed engines they use. That timing belt job seems hard as hell to do.DoinkMobb wrote:. I'll go back to Subarus, cars that are designed to be user friendly enough to the average mechanic.
If I had a lift and could stand under my Q and not have to lay on my back to work on it DIY repairs would be a heck of a lot easier. Checking and changing belts, idler pulleys and fan clutch was a major ordeal yesterday but this old f@rt is still able to remain upright and talk about it today. .Q45tech wrote:After you work on your first 50 Q you see how logical and easy everything is to change on a lift with $36,000 worth of tools.
NON OF 'EM ARE PIECES OF CAKE. Some may have more frosting than others.Jesda wrote:LOL, I've often felt the same. But when youre done you want to say "I AM THE GOD OF ALL CARS!" Plus, you have a Q to drive, which is always a positive thing.
Once you've wrenched on a Q, almost anything else is a piece of cake. Have a fan and radio nearby and take your time.
I second you on those LS400 Timing belt, starter job.Q45tech wrote:Again comparing V8 to 4 cylinders.Try working on any 90+ Foreign V8 and you will see the same or different problems. Try changing the timing belts on a Lexus or Audi V8 or the under plenum Starter on a Lexus. Try changing the 16 sparkplugs and wires and coils on a Mercedes V8.
Rich peoples cars, owned and driven by poor people who think they can go to Azone or PoopBoys.
People lust after the foreign lux 0 sports until they buy one with 100k+ on the clock.
If you replaced all the hoses, then the KS were right there.DoinkMobb wrote:While the plenum was off, I decided to change the sparkplugs and valve cover gaskets too. The sparkplugs weren't too bad, but the driver's side VC was just...annoying and aggravating. I was going to do the passenger side too, but thought "screw it, I'll do it at another time". And the knock sensors? No, I'm not doing those. Don't talk me into it, I'm not going to attempt it.
The engine bay of the Z32 Twin Turbo is the most unholy evil an engineering department has ever unleashed on this world. Or you could argue that its one of the most miraculous packaging jobs in history.Rex wrote:I recall a few early 80's domestic V8 cars that required going through the wheel wells to change the spark plugs. One specifically required you to drill wholes if you choose not to pull the engine for a spark plug change
Basically, over the years as cars have gotten smaller (compare Q engine compartment to 80's Caprice) and the technology and smog "attachments" have increased, working under the hood has gotten more and more difficult. If the Q's is frustrating, never offer to help someone with am90's 300z twin turbo.
you can see the light,just hope its not a train..........I know how you feel.DoinkMobb wrote:Hopefully by the end of the day today, I'll hate my car less. I can at least see the light at the end of the tunnel.
2.7T? I helped a friend pull off his downpipes once. Don't ever want to do that again.jimbyjimb wrote:.....Twin Turbo Audi V-6's .....
I'm can wholly sympathize. Nothing like the time I tried replacing my Alternator and pulled it out from the TOP. I was speaking in tongues and cussing in Chinese. Had to ban my daughter from the garage. It's also the reason why I changed my plugs at 120K back in 2000 and they are still in there at 228K.DoinkMobb wrote:In conclusion, the Infiniti Q45 is a stupid car and I hate it.
I ran plugs from 69,000 miles til 201,000 miles {132,000 on plugs} and they came out without any difficulty and all looked good- car ran/idled no different with new plugs- only changed them because valvecover gaskets needed to be changed due to seeping oil. Early plug changing is a total waste of time and money, only do them at valve cover reseal time.DrewQ45 wrote:
