Did not know that.qship96 wrote:
I ran plugs from 69,000 miles til 201,000 miles {132,000 on plugs} and they came out without any difficulty and all looked good- car ran/idled no different with new plugs- only changed them because valvecover gaskets needed to be changed due to seeping oil. Early plug changing is a total waste of time and money, only do them at valve cover reseal time.
Good point, Need to remove plugs every decade or so to prevent them from seizing.Desmoquattro wrote:You guys got lucky with your plugs. Mine were partially seized, as luck would have it number 8 (I think, the one next to the ABS unit) was the worst. I had to soak it overnight with penetrating fluid and use a breaker bar to inch it loose. I had nightmares of broken plugs and stripped threads the whole way through the job, which took me two full days. Made a big difference in idle and startup though, the electrodes were quite worn on the plugs I pulled (yes, platinum tips do erode if you leave them long enough).
Cool. I just did mine so that's one less thing to worry about. I had to insist on getting the NGK PFR5G-11 plugs. The parts guy kept trying to give me the Iridiums.qship96 wrote:Just do them everytime valvecovers start leaking {5-6 years or 100k} and you will be fine. Be sure to use factory spec NGK plugs as they have a special metal coating on threads to prevent sticking or galling of plugs in head.
My plugs were in for slightly over 6 years and 132,000 miles and came out without difficulty and still looked and performed good. Your results may vary based on engine wear caused blowby {worn rings}
I'm not driving a Premium Luxury Car...it's a Cheap Used Car I picked up because I needed a way to get to work, and I didn't want a Civic or a Corolla. The maintenance is a bit high, but I'd rather attempt it myself than be raped at the dealership.IceCubeFoSho wrote:You're kidding me right?
Premium Luxury Cars were meant to be worked on by the Premium Luxury Car's Dealer's Mechanics, not just anybody. Bentley owners don't change their own Sparkplugs.
Well, not fo rlong, that is certain.DoinkMobb wrote:
I'm not driving a Premium Luxury Car......
Plausible. But, a large percentage of the 90%+ of owners who have not had the pleasure of driving a Q brand new still have that magical thing called an imagination.maxnix wrote:
Probably less than 10% of current ever drove a G50 in like new condition, so they have no idea what they are missing.
Not very nice. I haven't been 17 for almost 4 years now. I'll be 21 in a couple of weeks.lasoyafan wrote:Haitian king take this as you will, but every time I see you post I get this image of a 17 year old kid who's Q45 is really his dads. You are obviously not an adult and your posts and comments are.... lacking intellectual depth.
Sorry I just had to go there. I'm done now.
Thank you. It is nice to be appreciated.jimbyjimb wrote:That cut at the King was completely uncalled for. I find his witty retorts a pleasantry. And, of the posts I've read, his input is also valuable. I don't see how his posts, as a whole, lack intellectual depth, nor have I ever recieved the impression that his car was "his dad's." What specifically in anything he has posted in the arcticle did you find to your annoyance? If you aren't specific how can expect people to change? You can tell more about a person by observing their tact in their criticisms of others than almost anything.
Thats about when I got my first Q as well. In 2003 I was 21, and paid $3600. Unfortunately, back then that kind of money got me a 170k neglected nightmare.Haitian_King wrote:
I purchased my Q myself sir. $3500 well spent on a 92 with 83k on the clock.
You must know some bright 17 year olds. I like to think of my writing as quite articulate and a breath of fresh air in the time of soaring illiteracy rates.
What about my post hinted at my assumed age?
Good site. Imagine the size of the crankshaft grinder lathe?Epod wrote:I agree with the original poster...I want an engine where there's room get at things to do work...
http://people.bath.ac.uk/ccsshb/12cyl/
