Jookmasta »
https://forums.nicoclub.com/jookmasta-u6633.html
Sun Mar 06, 2005 3:02 pm
Well i figured i share my experience as a forewarning to all that try this approach.
First off, let me say that none of this would be possible without help from Rick (240sxsickness), Will (willfastbackse), and provisional information from wdracing, klattr, and the nico and ka-t.org forums. So this all started pretty much last december. I first got the safc installed before christmas, and the mechanical oil pressure gauge was installed before that. Then came the Blitz DTT (boost gauge and turbo timer) which was installed mid January. After that, the SR 370cc injectors went in early february and the tapped oil pan was in about two weeks ago. Last but not least, my narrowband A/F went in about a week ago due to it being free!
So obviously there was really nothing else left to mount up except the oil lines, turbo, manifold, BOV, and intercooler. Obviously the piping had to be done when those things were installed and couldnt be fabricated without them on the car. Well it came down to this past thursday where we (me and Will) figured that we could knock it out and then go to the gym. So we started when i got out of class at four. Everything was running smoothly, got the front bumper off, aem intake off, exhaust mani, heat shield, egr stuff, and factory DP off by about seven-seven thirty. So all that was needed now was to install the stuff and be out to the gym by ten.
What do you think happened at seven thirty? RAIN! RAIN! RAIN! Now we were working on the car in his car port on the side of his house and he happens to have a nice big street light installed on the side of his house but this wasnt ordinary rain. This rain was cold (at least by our south florida standards) and the rain didnt stop at all the entire nite. Well we went to put on the manifold and turbo at the same time and it wouldnt clear due to the manifold being a side mount. This complicated things some what as now we had to put on the mani first and then the turbo. (not really complicated things but the car port isnt covered). So we get the mani on in about ten to fifteen minutes. Then the turbo is what killed a good majority of the time. Four bolts hold the turbo to the mani. This took about an hour and a half or so due to slippery hands, back pains and the turbo not sitting properly due to the A/C line. After about an hour and a half or so, the turbo is finally bolted on and rain is still coming down.
This is where all hell broke loose (and can be found in another thread). Well I go to install the feed line and i get the line ready with the teflon tape. I first installed the feed line into the turbo and that was all good. Then i went to install the other end of it into my fitting which has the extra port for the turbo oil feed line. When i first looked at it, I couldnt get to it without removing the oil filter. So then i removed the oil filter and proceeded to get the plug out of the hole which i needed. This i must say was a daunting task for me as for anyone that has dealt with anything in that area, there is no room and the plug was an allen key one. This took me about half an hour to get the plug out due to me trying to find the right key to use and me only being able to get about a 4 cm movement for each turn. Finally the plug was out and then it was just to screw in the oil feed line. That was done in about three min and all was well for now. Then I had to move back the fitting so that i could put on back the oil filter. This is where in my other thread, the fitting broke off into the oil pressure switch hole. It was a clean cut and the broken piece is still threaded into the block. I think it broke due to me getting at it at a bad angle or to the rain and my frustration but i was turning it left so i dont know why.
Now when the fitting broke, my ten foot SS line for my mechanical oil pressure gauge also broke. This could have also broken the fitting due to the strenght of those SS lines. So we left the car after that occurred cuz that just brought down all the moral and it was still raining, and it was eleven thirty at nite (had class at nine thirty).
So he dropped me off and we planned to work on it the next morning. So after getting about five hours of sleep, i rode with my Dad to the car and we reached the car at around eight. We then proceeded to start on it around eight thirty. We gloated on the broken fitting and then got the intercooler mounted. This took about forty minutes and it was tacked on by brackets and tie straps. Next thing was to get the oil return line on.
So before i went to class, i called the tow truck to come tow the car as they usually take a while to get there. So i went to class and then called Will to see how the progress was going. This was the second speed bump in the process. All that was left to do was the oil return right? This was done by Will himself while i was at class. Needless to say, the oil return hole on the turbo was touching the A/C line and this is what was complicating the turbo to mani bolt on the previous nite. So the tow truck arrived and he had to turn it away since that was a serious problem. No return line = no way to use turbo. This is where the "talk" occurred and we were contemplating on just putting the car back to stock.
I dont know how he did it, but he got it to fit so that was good. Next problem was to get the oil return line attached to the oil pan. This would require cutting of the oil line since the line is 22 inches long. Unfortunately, he wouldnt b able to cut it since u cant cut the line urself with a saw since its already attached to the car.
So he called me to let me know the progress and i called a tow truck again to get there. He scooped me up from campus and then when we got there, the tow truck was already waiting for us. So needless to say, the oil return line didnt get cut yet. So now the car is currently at the muffler shop. It arrived there on friday at four and the shop closed at five so no work was done on it. Then on sat, no work was also done on it due to it being very complicated according to the owner.
The two major issues with the piping is that the intake on the turbo is right in front of the power steering line. This means that there will be a VERY sharp bend in the intake pipe. Next issue is the cold pipe. We didnt get a chance to remove the other resonator on the front of the car by the radiator so hopefully the shop will remove for us. As it is slated, i should have the car back on wed but the car still can't start due to the broken piece. This will hopefully be extracted tomorrow by me and rick so we'll see.
If the piece is extracted, then i can just replace it with the new fitting which should b in the mail by tomorrow. That should clear up that issue and hopefully the muffler shop can come thru with success on the piping. My only other concern is the cost. The muffler shop has given me a quote since they havent really done anything with the car. I am expecting a call tomorrow from them but i really am worried about the cost cuz if it is too much, i may have to tow back the car to Will's place. This shop does good work as they did build the jig that is used for all of the s13 BRM exhausts. So we will see..........sorry for the long post but it had to be done
Modified by Jookmasta at 1:18 AM 3/7/2005
