Bigvinnie wrote:
How bout this so you understand better. On Crank Horse Power dyno testing there is only a header... Right That means Max crank Horse powerout put is that of one 155CHP. Now you cant decipher Crank HP from Wheel HP. Once the engine is in the chassis the engine will always be using it's 155CHP maximum potential at peak RPM. Due to bolt ons, and drivetrain numbers at the wheels change. But the fact is the engine is always pulling 155CHP you just can't see it at the wheels. So now you have added an exhaust to the end of a header that already had a yeilded a maximum power out put of 155CHP. That means you are just moving numbers around because you have extended a pipe weither it be 2" or 3" I really don't care. That is why exhaust tuning is developed. Using different diameter pipes after the header will only shift numbers into the earlier or later rpm. That is why 2.5" in my opinion works better even constant flow that is slightly larger than my DC sports collector.
To scooby: all Nissan USDM engines go through this dyno testing, NO exceptions, and it's mandated by the EPA to measure pollutants from HP output.....
Okay try to invision this.
Nissan measures power to their engines with their exhausts on.
This is why Spec-V's claim 175 crank hp versus the SE-R's 165 crank hp.
The exhaust difference increases the Spec-V's Crank HP. Nissan has announced this. The dealers will tell you this.
Exhausts and intakes CAN and DO increase crank hp. There are a few bolt on products however that do NOT add crank hp but DO increase more whp.
These are products that do not adjust how the engine breathes and produces power. These are things like crank pulleys, lighter driveshafts, hell even synthetic transmission fluid has shown to release a few more ponies to the ground.... but if you look at the dynos of these mods the power increase is linear....meaning it's obvious the engine is operating no differently...no changes to engine power.
Adding exhausts, intakes, and other bolt ons DO change engine power. Fact.
From what it sounds like you're saying and what I'm interpreting is this:
Car companies rate their engines without any power robbing add ons like exhaust, intake, etc.
Then they throw the engine in there which reduces the engine's output taking the crank hp rating down from what they advertise.
They cannot do this: Why? False advertisement. The most recent example has been RX-8s. They were overrated hp numbers because of this reason and the company recalled those customer's cars IIRC.
Therefore The engine going into a 240sx is making 155 horsepower at the crank. At the wheels it is losing ~15% of it's power so it's around 130 to the wheels.
If you add an exhaust and you gain 10 whp to total 140 whp....you are now making around 166 or 167 Crank HP.
Simple as that.
Point. Period. Paragraph.
-Greg
