The "I'm New Here And I have A Simple Question Thread" v2.0
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
Theres always the devil you know, and the devil you dont..... Just because they say its a good motor, does not mean it is. If you do go with an RB,pull the head, have it checked, do a timing seat and gaskets, do a water pump, etc
bodybuilding88
Car: SRT
OutToWinPAHC wrote:Theres always the devil you know, and the devil you dont..... Just because they say its a good motor, does not mean it is. If you do go with an RB,pull the head, have it checked, do a timing seat and gaskets, do a water pump, etc
If i bought a rb i planned on new headgasket, waterpump, better oil pump. Thanks for the quick responses everyone i appreciate the straight answers and no flaming since im new here :dblthumb:
KYZAAC
Car: 92 240sx SR
i have a few questions.
1. im removing the hicas on the hatch, right now im just worried about running the lines in the engine bay.
do i need the power steering cooling loop? it runs from the p/s reservoir, across the cross member to the hicas solenoid. if its needed, how can i run it?
2. what size are the threads on the steering rack hard lines? they go from the pump to the rack.
i was putting new lines on. the old fittings were seized to the line and snapped, my local auto parts store never had any that size, i gave it to a buddy whos a mechanic and he couldnt get the right size either.
3. i asked the other day about running a Non-ABS Master Cylinder with an ABS Brake Booster. "Out To Win" said it worked for him, and smurf said it did not work for him.
if i run the front brake line off the master cylinder into a fitting, and run 2 lines off the fitting to the front brakes, technically it should work, right? it'd be the same as running the line into the abs unit.
Thanks
PapaSmurf2k3
Site Admin
Why are you debating this brake thing? What's your plan? You currently have ABS but for some reason are trying to run a non-abs master? Delete ABS? Save money on not buying a non-ABS booster?
Seems like you can just do whatever your plan is on the cheap side, and if it doesn't work, buy the non-ABS booster.
KYZAAC
Car: 92 240sx SR
yea, im deleting abs. i pretty much just want a clean/simple setup, im doing an sr swap, i stripped the whole front end until there wasn't a bolt left, i just installed all new suspension, now im putting the engine bay back together, the abs had something stupid wrong with it, so im just leaving it out. i don't want to buy a non abs BMC for $100, then if it dont work, spend another $160 on a booster. i figured i can pick up a tee for a few bucks an stick with the ABS Master Cylinder & Booster.
SOUNDWAVE333
Car: '90 stock s13 hatch
Can you lower the '90 s13 HB on it's stock springs? what do you do?
Mitchum
Car: 2000 Dodge Dakota
1995 240SX
I know this has been topic has been kicked like a dead horse,but I cant seem to wrap my head around proper wheel sizing.
A local guy is selling some 5Zigen GN+ wheels for pretty cheap, they are 17x9.5 5 lug wheels comming off of a 180SX. I drive a 1995 S14 with Stance GR+ coils (not installed).
My motor and car are still being built with hopes of atleast 350WHP, id like as much traction as possible with no over fenders or any wide body or anything like that, will these be a good fit for a street car?
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
Depends on your choice of tire and the wheel offset. You can run a 285 on a S14 with a rolled innder lip.
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
SOUNDWAVE333 wrote:Can you lower the '90 s13 HB on it's stock springs? what do you do?
No you donr, and why do you want to lower, what do you use the car for, and how much lower?
speedeast
Car: 1990 240sx VH45 FB & 1993 300zx
Shocks are for recoil, springs determine your height... So... stock springs = stock height.
Caveit77777
Car: 1996 240sx SE
So I accidentally ordered a rear upper strut bar rather than the front one for my s14. No worries though I'll get the front one anyways. I never thought about this until today but how exactly do I hook this thing up since the rear strut towers are sort of inaccessible?
speedeast
Good luck.
PapaSmurf2k3
Site Admin
speedeast wrote:Shocks are for recoil, springs determine your height... So... stock springs = stock height.
Unless you cut or compress them.
speedeast
True, but you and I both know that's not the way to go.
PapaSmurf2k3
Site Admin
Yeah I sure as hell wouldn't do it.
Caveit77777
Car: 1996 240sx SE
speedeast wrote:Image
Good luck.
awesome thats just what I needed. So I just drill through the rear where the speakers are and bolt it up?
SpeedKills84
Is navan a japanese word, is it an aero company? any info is appreciated, thanks.
speedeast
Finnish word for umbilical. I googled it just like you probably did and found evidence of aero, but no real concrete proof.
Eion
Car: zenki s14
so i'm removing the double sided threaded studs on the intake manifold and i'm wondering if the any of the bolts from the upper plenum are long enough for it?
speedeast
Just take the studs to a hardware place that matches bolts and pick some up there. On an aluminum head, bolt specs are crucial. Measure the thickness of your header too so you can get the right length.
nismoracingsx
Car: 1993 White 240sx Coupe
where is this piece on courtesy parts? I can't seem to find it...
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
StonedRhyder
Car: 91 240sx ka24de
Hey guys, I am able to get to work on my car again this weekend. Everything is double checked for timming marks aligned, cams in the correct postition, dizzy also,new plugs,wires,cap,rotor,battery,ignition module, and coil. The car will turn over but never start. I dont have a volt tester thing but I did have a test to see if there was current to the fuel injectiors. They were (hot) live even when not trying to start the car. Would that be a sign of a bad grounds? Im going to clean everything up, double check the knock sensor. Kinda stumpt as of why its not starting. I have been posting in here for awhile but if you cant recall......1991 ka24de 240sx with new BC stage 2 cams that i can run stock head internals. Since I dont get to work on it very often was just wondering some other people input of suggestions of what to try/test that would get my baby back up and running again :mike
speedeast
It needs two things, spark and fuel. Are you sure you're getting both? And at the right times? Plug wires hooked up right? 1,3,4,2
fwdKillaInDa206
Car: 1989 240sx hatch shell...
ok im somewhat new to the 240sx game and was wondering if a 1989 KA24e single cam transmission would work with an ka24De engine
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
They are the same trans
fwdKillaInDa206
OutToWinPAHC wrote:They are the same trans
thanks bro
PapaSmurf2k3
Site Admin
StonedRhyder wrote:Hey guys, I am able to get to work on my car again this weekend. Everything is double checked for timming marks aligned, cams in the correct postition, dizzy also,new plugs,wires,cap,rotor,battery,ignition module, and coil. The car will turn over but never start. I dont have a volt tester thing but I did have a test to see if there was current to the fuel injectiors. They were (hot) live even when not trying to start the car. Would that be a sign of a bad grounds? Im going to clean everything up, double check the knock sensor. Kinda stumpt as of why its not starting. I have been posting in here for awhile but if you cant recall......1991 ka24de 240sx with new BC stage 2 cams that i can run stock head internals. Since I dont get to work on it very often was just wondering some other people input of suggestions of what to try/test that would get my baby back up and running again :mike
If you are getting spark and fuel, start messing around with your ignition timing. Its pretty easy to get it off a tooth or so.
speedeast
Yeah, as simple as twisting the dizzy.
J14cm7
Car: 95 240sx S14 SR20det
Hey guys im not new here but i have a simple question. I have an S14 Sr20det. The other day i went to get my valve cover powder coated and they said they thought it would melt the plastic and sealer that is on inside of the valve cover. I know nothing about it except that i have seen plenty of them powder coated before.
Did a bit of searching but nothing came up that said people have had this problem before.
I can post better pics if need be.
