The Great Mount saga continues
NISMO_RB25
Car: 1992 240SX with RB25DET, 1987 RX-7 TII
First let me say that I don't care what mounts you use or if you use the RB X-member. That decisions is yours and yours alone.
Their has been alot of debate recently, so I figured I would post a few pics of what the RB25DET instal looks like in an S13 (mine is a 92 SE) using Mckinney mounts.
Hopefully this info will help people decide what they want to use.
I had the car on jacks waiting for my VLSD axle, so I figured now was a good time to take the pics.
Here is the Driverside mount installed.
NISMO_RB25
Passenger mount
NISMO_RB25
transmission mount
NISMO_RB25
Here is a picture from above to show you that nobody will see the dent to the firewall.
PROJECTRB240SX
Car: 1972 DATSUN 240Z W/ SR20DET
THANKS NISMO THIS SHOULD HELP SITUATIONS SOME.
NISMO_RB25
here is a shot from the front of the car
NISMO_RB25
a pic of the shifter in neutral from above, so you can see that it is centered.
NISMO_RB25
I also posted the full size pics in the members ride section. Enjoy.
Rember, buy whatever the hell you want or don't.
For me, the mckinney mounts/driveshaft and wiring was well worth the $$, and I installed it all in one weekend by myself with 4 jackstands and an engine hoist.
Wulfgang
Ok, maybe I'm stupid, but... could you give me some orientation for those pics? I can't tell which way is up or down or right or left.
Btw, that shifter position does look stock. I am impressed. First pic I have seen of a shifter that doesn't look like it's 0.5-1.0" forward.
Also, I see no exhaust hanger on the transmission mount. Is there one that I can't see, or do the McKinney mounts not have that?
[EDIT] Ok, I see the oilpan in the first pic. Those first 2 are from the bottom, aren't they? And the mount must have a flat piece of metal that goes over the x-member where the original mount sat that is not shown in the pics, right?
NISMO_RB25
I was laying under the car with my head/camera towards the front bumper. So the pics are from the front of the car angled back. What you are seeing is the mount on attached to the 240 crossmember (it bolts into the crossmember where the original mounts went) You then drill on hole in the crossmember and attach the bolt you see.Look at the pics in the members ride section. It is hard to tell what is what in these little pics.
No exhaust hanger on the mount, but there wasn't one on the stock transmission mount either that I remeber? hmmm.
PROJECTRB240SX
ITS NOT ON THE X-MEMBER ITS ON THE MOUNT.
NISMO_RB25
What is not on the X-memeber?
PROJECTRB240SX
THE EXHAUST HANGERS FOR THE TRANSMISSION AREA
Wulfgang
True, but that McKinney setup includes the mount and the x-member, neither of which appear to have a hanger.
However, I'm not sure this is a problem. On my car, the hanger appears to exert a lot of force on the exhaust, which may be worse than having no hanger at all.
PROJECTRB240SX
I'M NOT RUNNING A DOWNPIPE HANGER ON MY CAR.... IT MOVES SOME BUT ITS NOT TOO BAD.
NISMO_RB25
I don't have anything supporting down pipe, and didn't see any type of connector on the pipe for one? Looking at a pic of the stock exhaust next to my N1 Dual, I don't see any hanger that mounts to the transmission brace on either one of them??
I will look this weekend to see if I can tell what you are you talking about.
My VLSD replacement axle, and a pair of S15 seats are going in this weekend, so I will be under the car again :)
PROJECTRB240SX
THE PART THAT MOUNTS TO THE TRANSMISSION IS THE COLLECTOR PIPE ON THE KA24 OR THE SR20DET DOWNPIPE.
NISMO_RB25
Ok, I get it now. When I yanked the KA out, I never disconnected the transmission from the motor, so I never even noticed that the KA's header connected to the transmission.
rbsileighty
Car: 92 S13 Hatch w/ RB20 & 05 Audi S4 Avant 6MT
We are going to make one for Hybrids car over the long holiday (DP FP hanger) due to his front pipe has started to droop... and his car is really really low in the first place.
That is cool Mack, I like the way you added the extra bolt bracket on the front of the X-member instead of that piece the other mounts tend to use as a rest for their mount extentions. I was thinking of using the same method when I try to make my mounts for my car. With the tightly sprung FLT-A2's on the car, I would like to know my mounts are secure with that much of a load above them.
FAST-DATSUN
Yes if you want it we will make one for the stock hanger for the kit... O-B-Y We have new isolstor in work for the engine and trans made from POLY, they will be done soon for the kits and everone can retro-fit for cost....and mount kit after 5/1/04 will be stronger as we changing to POWER COATING....HA<HA
b-s14
hey mack, are u sayin the mounts that are currently on the market are not as strong as the one ur currently making..? i'm currently looking into getting the mount/driveshaft set for rb26 going to s14.
rbsileighty
I'd imagine he is teasing about one of the comments made in an old mount post.
b-s14
i hope, i'm very gullible person :oy:
xjon
Car: 99XJ, 93 240coupe
something about powder coated mounts purdier and stronger.
How much to retrofit for the new poly's and when?
FAST-DATSUN
$60 shipped for all 3 mounts for the retrofit guys. waiting for them to come in from the manufactor in about 2 weeks had to get them special made for the engine..Yes, the power coating is the hot way to get better mounts..
b-s14
so summing up everything, these new mounts your making is like an upgrade to people with the mount/drive shaft kit... ? i dunt understand...
Toad[^_^]
Sorry to interupt but would it be inappropriate to ask exactly how much I should dent the firewal? I didn't think it to important to open up a new thread...
FAST-DATSUN
on most car you do not need to do it except for making sure it not going to make noise about 3/16 to 1/2 is all that needed but we usually do it a inch to unsure that there is enough room so there is no rubbing....
FAST-DATSUN
The up-grade is to the rubber isolatior for the engine and trans not the metal parts. WE are trying to act on customer inputs that they want a firmer better looking materal, and there was nothing wrong with the rubber, just a power coating is comesitc over paint
b-s14
so its a basic upgrade... for 60 bucks.. i think its a must!!
