Although at this point I think I will put the OEM back in the loop.
After I pulled the original TPS I compared Ohm readings with the replacement and there was a noticeable difference between closed readings and wide open readings.
The replacement TPS was dead on specs per the FSM.
Thanks for the pic JD !!
That's the one section I didn't look through.
I ordered it from Rockauto .
It seems to shift right where it should now.
Not sure what you mean by the kick down switch adjustment.
I don't have it floored at 60 MPH.
