Ive also noticed when I first pull out of the driveway and start up the street ,
with even pedal pressure the rpm's go up and down a tad.
The speed also changes so she's not slipping.
I'm thinking the two have to be related.
transmission Diags pass fine and the consult shows the TPS dead on.
Anybody have any idea what might cause these two symptoms ??
I need to dig into the FSM and see what all parameters must be met to achieve lockup.
All I know of for sure is the transmission temp.
It doesn't even try to go into lockup till the temp gauge is almost at operational level. (Just shy of halfway up)
