mello88 wrote:What maintenance stuff did you do when the motor went in 2 years ago?
Here's a few things you might want to think of doing:Leakdown testWater pumpTiming beltTiming belt tensioner, guideOil pumpHead gasket3 angle valve jobExhaust manifold gasket and studsNew belts, rubber hosesPressurize the manifold to test for any boost leaks (my old TB/TPS leaked)
Other than that, change the fluids, change the spark plugs, it should fire up if it was running good when parked.
Thank you.
nizmo zilvia wrote:Sell it if you dont kno what to do.
Your not giving us enough info on what stage your on of the swap.
Why the hell would I sell my engine? I came here asking what I should do as a next step, not because I want to get rid of my engine.
Three years ago a shop here in town put the engine in the car. I really dont know what kind of maintenance they did to the car before they put it in, they never told me. I should have asked, but back then I didnt think to. June of 2006 a girl pulled out infront of me and I T-boned her, the car sat for over a year and I just pulled the engine out and thats where I am at with the swap.
Abdo wrote:
"[C]ame out of a car", all RB's, at one point in time, were in a car. So your situation is NOT AT ALL different than a new swap. Read the stickies and you should be fine.
I was going under the assumption that most people get their engines straight from a japanese vehicle that may have been sitting in a junkyard for who knows how long. I took into consideration that I used my engine for 2 years before it was wrecked and then sat up, didnt know what the typical rundown on that kind of situation would be, thanks
