Tsukiko »
https://forums.nicoclub.com/tsukiko-u52908.html
Tue Jun 26, 2007 8:54 am
only if they were to swap out the engine with a *gasp* chevy.
in which case you should prob be kicked in the nads. keep in nissan. keep it 180/240.
no skyline nonsense (we all saw how that ended up). and im seriously diggin the moonroof rear window, but-
take the hardware off the moonroof, mount it to a properly sized rear window, maybe put two of the open/close latches on it for good measure, and rock that ish. edit: on second thought, and after inspection, the stock moonroof may do the trick.
