Fireplug »
https://forums.nicoclub.com/fireplug-u28343.html
Tue Feb 07, 2006 6:41 pm
Complete Mod list:
BLOCK:[*]Cleaned/magnafluxed[*]Decked[*]Sleeved[*]Balanced[*]Bored .040 over and powerhoned[*]Crankshaft has been micropolished[*]Wiseco pistons (9.0:1 compression) (87mm)[*]Darton Sleeves[*]Carillo H-Beam Rods[*]Carillo Carr bolts[*]ARP Main stud kitHEAD[*]HKS 272 Step 2 cams[*]HKS Adj. cam sprockets[*]Tomei Rocker Arm Stoppers[*]Ferrea double-valve springs,titanium retainers, seats[*]Competition 5-angle valve job w/ radius entry[*]ARP Head stud kit[*]Power Enterprises 1.5mm metal headgasketENGINE MODS[*]Precision PT67 Turbo[*]SST stainless top-mount manifold[*]SST stainlesswastegate dump tube[*]Tial 40mm wastegate (1.0 bar spring)[*]Tial racing 50mm blow-off valve[*]SST 3.5" stainless downpipe[*]3.5" HKS stainless cat-back exhaust[*]Custom 4" stainless intake pipe w/ K&N filter[*]Blitz LM Front mount Intercooler kit (modified coldpipe)[*]SST custom hot pipe[*]KOYO radiator[*]FAL dual 12" FAL fans[*]Greddy intake manifold[*]Greddy Catch canFuel Delivery/Ignition setup:[*]SST fuel rail (top feed) with -8 fuel fittings[*]MSD top feed 96/lb injectors[*]Aeromotive FPR[*]-8 AN Teflon Stainless Braided Fuel Feed line[*]-6 AN Teflon Stainless Braided Fuel Return line[*]Twin Walbro 255lph fuel pumps (2nd wired to kick on via AEM)[*]AEM EMS[*]AEM 3.5 bar map sensor, IAT sensor[*]Splitfire DIS coilpack kit[*]Hallman mbcDrivetrain:[*]Nismo motor and transmission mounts[*]Chromemoly 4340 Stage 3 axles (LS auto)[*]Chromemoly 1-piece driveshaft[*]RPS TurboMax 6 puck clutch[*]Fidanza Lightened flywheel[*]300zx transmission upgrade[*]Mazworx 300zx transmission adapter plate[*]Short Shifter[*]vlsd[*]Mickey Thompson ET streets (255/50/16)[*]Driveshaft safety loopSuspension/Brakes/Wheels:[*]Buddyclub P1 wheels (16/7.5 fronts, 16/8.5 rears)[*]FD RX7 wheels (16x8 front and 16x8 rears)[*]Tein HE coilovers[*]Whiteline polyurethane bushing master kit: (upper/lower links, subframe spacers, TC, etc.)[*]Front/rear strut tower bars[*]300zx brake master cylinder[*]300zx 30mm calipers[*]Brembo slotted 300zx front rotors[*]Brembo slotted rear rotors[*]Stainless steel brake lines (PDM racing)[*]EBC green pads
