Jeff Williams »
https://forums.nicoclub.com/jeff-williams-u431.html
Sun Aug 29, 2004 3:10 pm
The great thing about the kit, is that you will probably have everything you need, once you get the plenum off. There is not a lot of spare room, under the plenum, for hard piping. Plus, there needs to be some flex in the pipes, in order to get the thing back together.
You are correct, that PVC can handle hot water, and it is much cheaper than custom pre-fit hoses. The problem arises, when you add vibration, heat, and glycol to the solution. I doubt the connections could handle the stress, of under hood life.
Once yo uget the plenum off, and start tearing into the hoses/lines, yo uwill not want to have to do it again, for a while. That is why a lot of people say to replace the knock sensors, and the wiring harness. These things fail, and you ahve to remove the plenum, to replace them.
I would like to see someone do a SS braided line kit for the car. The problem is, that the hoses should last another 10 years, and 200,000 miles. Not many people keep their car 20 years, and drive 400,000 milesm though.
