The birth of a beast
brunswick240
Car: 93 240sx SE
So i got my kit tonite, came home, checked all the parts over, then went right ahead and ordered a pizza and started working. Ran into problems as usual, such as the Inj cap/cover (or w/e the hell theyre called) snapping, gas fumes through out the house from the removal of the ka injs, trying to find out how to mount the smic, getting the f-ing heat sheild off the dam headers (what a bi tch it is to get that stupid heat sheild...mine had rusted nuts and bolts, so we started to cut at it which made it harder : ). Then it looked like it was down hill from there...nope couldnt get the nuts on the ka down pipe off, spent about a half hour pb-blasting all of them (which helped for two, ones still on there), but of course like i said theres still one on there which just happens to be in THE worst spot, cant get my impact up there, cant even get my breaker bar w/ extensions up there : . But w/e here are some pics of the status of the car now, if anyone has any tips for taking the ka down pipe off, please share, also i will be posting more pics as we move along. Ive got some questions about sensors and what not, but thats for later : . So with out further delay heres your pics...Completely stock to having the 370s in along with the full cold side done, bov mounted, smic installed, and heat sheild off (god i hate that stupid thing 3 hours me and my friend spent working on it and what happens??? my 12 year old brother got it off in 3 mins ) But ya heres your pics enjoy!
Chezedik
Car: 1991 Nissan 240sx
Looks like the kit is homemade from SR parts, but what turbo?
sunnys14
Car: S14
most likely a t25 off an SR. i dont think a t3/t4 can handle a SMIC
Jookmasta
i know what bolt ur referring to.......................its gonna be a two man job. one of u needs to be up top with a rachet on one end. ur gonna have to be underneath the car with a wrench or rachet on the other end. u MAY lose some skin and blood so put on some gloves as u know our cars have some sharp surfaces that are purposely in weird locations waiting to take blood from you so that it can go to the blood bank. the pb blaster should've worked tho.
Florida240sx
I had my car up on 4 jackstands.Was able to put my foot inside my fenerwell for bracing, and the concrete on my back kept me from sliding.That's how i brokwe that one loose.On a side note....You won't need it so if you got a sawzall have fun like i did with my egr
KATwo40
Car: 1993 240sx KA-T
If you can find a way to get a good breaker on it, that's better than the impact. The steady pressure will twist the stud off. That's how I did mine.
brunswick240
Car: 93 240sx SE
Thanks for the replies guys...ya its just a basic setup for me to play around with and get the feel of boost (a.k.a. budget haha). But ya you guys guessed right, t25, sr smic, rfl bov, ssa bottom mount (the welds actually surprised me an a pro. welder i took the mani to). And all the other goodies. Do you guys think you could show me where i need to bung the oil pan? That would be great. Ill keep you posted.
fiznat
Car: Grown up :(
Yeah why are you bothering to take the nuts off of the stock exhaust? Just cut that thing right off of the car! I cant imagine that you ever plan on using that part again, right? Cut it!
brunswick240
Car: 93 240sx SE
Haha cutting it is then, ive just got one question. For the oil pan, where does the bung need to be put in at? And can i just thread it in or do i have to have it welded? I got a T Flange with the kit, so that means that both the return and feed hook up to that right? Thanks for all the help guys...all im waitin on now are the answers to these questions lol and my fp and safc. Thanks once again, this forum rocks
Chezedik
We discussed this in another thread. You will want to weld it on. You could find a way to bolt it on, but if that thing breaks, it's good bye engine and turbo. Sorry it can't be easier, I wish it could be too. But good to see you will be boosting soon. Good Luck!
brunswick240
Car: 93 240sx SE
Ok thanks, sorry that i didnt search. Does anyone have any pics of their oil pans with the bung welded on? That would be extremely helpful. Thanks guys
brunswick240
Car: 93 240sx SE
So i thought i got farther after cutting the ka down pipe off, but then i spotted another sensor, this is the last thing i need to take off to get the headers off and get the turbo mani on...Heres some pics, i cant get this stupid thing off and its driving me crazy. Do I even need it? lol
straightedge
Car: s13 hatch
thats is the tube for your aiv valve. (air injection valve) which is for emissions, you wont need it since you are putting on a different manifold and putting the turbo there. all it does is inject air into the exhaust stream to continue the combustion process of the few unburned hydrocarbons after the spent gasses leave the cylinder.
fiznat
Car: Grown up :(
I'll give you the same advice again: cut it offfff! lol
EDIT, its your EGR btw...
TOPSECRT88
Car: S14
haha you got owned by your 12 year old brother.
brunswick240
Car: 93 240sx SE
Thank you, makita here i come!!! As for the 12 year old owning part ya i know pretty sad, i guess thats what happens when its 11 oclock and youve been working for 5 hours straight...lol o well its off isnt it? haha thanks for the help once again, goin to cut the sensor off then ill post up more problems lol
PapaSmurf2k3
Site Admin
it shouldnt look like a sensor, sensors have wires and crap going to them. If its just a pipe, its your egr or AIV system. you should COMPLETELY remove your aiv system (the thing that used to go to your stock airbox). This thing just takes up a whole lotta space in the engine bay. once you get it out, you should have more room to get to your manifold bolts and all sorts of other crap
brunswick240
Car: 93 240sx SE
80% DONE!!! WOOT All i have to do now is the oil lines (includes tapping the pan) and bolt the downpipe up!!!! Besides that im good to go, post more pics of my battered up downpipe that i got for free . But heres some pics for now
s13drft89
Car: 1991 Twin Turbo 300zx & 1968 Mercury Cougar
Hey good job looks similar to the same setup as mine, but i do recommend rapping up those metal brake line leading to the brake booster, with a type of hiet shield. If not have fun stopping . also i have a little question what did you do with the vacumm lines leading to the aiv, (sensor) theres two of them. also what piggy back system do you have? to control fuel, air. also if you can im me at s13drft89 using aim thanks-Ricky
Chezedik
I AM SO ENVIOUS. Albiet mine will be more powerful, your boost will be instant and power should be good.
slipnfall
Car: '06 D40
Since you asked for a pic of an oil pan, here's mine: I don't have AC so I think you'll need to move it forward/backwards some to clear the AC bracket. It's best to decide on a position from above, because you want a clear shot(read: straight down, as vertical as possible) from the the return side of the turbo.
Chezedik
Slip, is that welded, or did you nut it on the back side?
slipnfall
Car: '06 D40
Welded on the inside only... wish I had gotten a picture of it from the other side, the weld shop did an awesom job. It's a -10AN weld-in fitting from Summit(I think Earl's Racing makes it).
brunswick240
Car: 93 240sx SE
Looks awesome thanks, does anyone have any pics of the feed lines on the block? Thats the part im stuck on right now.
straightedge
Car: s13 hatch
fiznat wrote:Yeah why are you bothering to take the nuts off of the stock exhaust? Just cut that thing right off of the car! I cant imagine that you ever plan on using that part again, right? Cut it!
the egr pipe is almost a straight pipe that comes off the manifold closer to the 4th runner. the aiv pipe is the curved pipe in the picture
fiznat
Car: Grown up :(
brunswick240 wrote:Looks awesome thanks, does anyone have any pics of the feed lines on the block? Thats the part im stuck on right now.
Sure thing:
brunswick240
Car: 93 240sx SE
Wow i dont think you know how much you helped me! THANK YOU SOOOOOO MUCH! Nico effin ROCKS!!! Thanks to all of you guys I really apreciate all of the help, so where do i send the money to? hahaha thanks guys
fiznat
Car: Grown up :(
brunswick240 wrote:Wow i dont think you know how much you helped me! THANK YOU SOOOOOO MUCH! Nico effin ROCKS!!! Thanks to all of you guys I really apreciate all of the help, so where do i send the money to? hahaha thanks guys
haha glad to help! All we ask is that you keep coming back, show us how your car is coming along, and help other people out with what you learn.
Cant wait to see how the car comes out!
Chezedik
Brunswick, you can get an excellent 'T' at Tunertoys.com for 20 bones. I will be excited to hear the results.
You can thank us by enjoying the site and inviting all your friends...
Glad to see you got your questions answered.
