The $67 Oil Change
longo
Car: 2007 Versa SL, CVT
I guess GM engine builders didn't care what Brand of oil you put in ithe motor, as long as it was the right viscosity and changed at the indicated time..
Dino or Syn, didn't matter.
They could have been on to something.
longo
dusred wrote:I just got my corolla serviced and it cost me $85.00 from the dealer.
WOW guys, here's a poster on this Forum with a 2009 Corolla..wonder if he will share his best MPG's number with us?
Please?
DejaWiz
Car: 05 Honda Odyssey EX-L
See sig for details.
longo wrote:I guess GM engine builders didn't care what Brand of oil you put in ithe motor, as long as it was the right viscosity and changed at the indicated time..
That's what's confusing me. Some synth oils are available in only single weight viscosity. E.G. SAE30 vs dino 10w-40.
feloniousmonk
$67 for Mobil1 isn't bad compared to the $330 I once paid for an oil change for my BMW using Castrol TWS 10w60, the only specified oil for the S54 motor (@ over $10 a bottle). If you really want to save $, get yourself a Mityvac 7201 fluid evacuator/dispenser, also known as a top-sider. It is pretty much ready to use right out of the box, but I recommend getting some small diameter hose clamps on the hose couplings to keep the hoses from coming undone during use. You'll want to cut a little notch at the tip of the tube that goes into the dipstick tube so that when the tube hits the bottom of the pan it won't get full suction and stop pulling up oil.
1. Just before performing the oil change, drive the car 10-20 minutes before doing the oil change to get the oil well circulated and hot. Idling is not good enough, drive it.
2. Park on level ground, shut the engine off. Open the oil cap.
3. Remove dipstick and stick the Mityvac's tube down the dipstick tube as far down as it'll go. Make sure the valve switch is on evac, pump the handle 10 to 15 times and it'll start pulling oil out. Don't worry about not pulling out any particles or sediments changing oil this way. The job of the oil filter is to catch these particles, as long as you always change the filter with every oil change, you are fine. If you are finding metal particles in your oil and oil pan, you've got greater issues than a $67 oil change. There are some engineers on the BMW board who have done oil changes this way for many years with no issues. Blackstone Laboratories oil analysis results have confirmed it as well.
4. The Mityvac has volume markers on it, you can see how much oil you've pulled out. You may need to pump it a few more times in the process to pull all of the oil out. Once done, it should be the same amount the service manual indicates to add for oil changes.
5. Install a new filter.
6. Add new oil. Let it run for a little, then double check dipstick level etc.
7. Every few oil changes or so check the drainage plug for seepage, if there are any, replace the crush washer. Chances are you won't find any.
Clean up is fairly simple. You can use the dispense setting to dispense oil into a container to take to a recycling station or you can pour it out the top. Remove the hoses and blast brake cleaner into it to clean out any oil in them. Hang them up and put rags under the tips and let it drip out. For the Mityvac itself, spray brake cleaner into it, slosh it around and dump it out, repeat a few times until you think it's clean enough. Brake cleaner fluid evaporates pretty quickly so you can just leave the Mityvac uncorked (rubber stopper) and air out. Do not store the Mityvac corked. Oil contains rubber swelling agents. If you leave the stopper in, it may swell and become difficult to remove.
You can get teh 7201 from Amazon http://www.amazon.com/Mityvac-...r=8-1Shop around online, it may be cheaper elsewhere. Price fluctuates from time to time.
longo
I saw one of these oil pumps being used in an a/t repair shop once.
Most a/t's have no drain plug and it's a messy business to remove the pan to dump the oil.
My Honda Odyssey a/t dosn't even have a pan! To change the a/t fluid on that one it's a crazy system..
Drain out the 3.5 quarts, refill,( Honda ATF only) , drive around the block come back, do it again, drive around the block, come back and do it one more timeAnd BTW, getting the new a/t fluid back in is like trying to stick an angle worm through a keyhole.
You have now mostly clean oil in the a/t.
I think if one had several vehicles to service, the Mityvac would probably get a lot of use for both engine and a/t's.
I have never thought about sucking out the engine oil tho, as I am already under there digging out the old dirty filter, so pulling the engine pan plug is about all the fun you can have on that job.
I use Magnetic Drain Plugs on everything I have, as I like to see if there are any boogers in my oil when it's time to get down and dirty.
I checked your Amazon link and eBay, Amazon with free shipping seems the best at about $65.00 for the unit.
