eastcoastchaos »
https://forums.nicoclub.com/eastcoastchaos-u4408.html
Mon Aug 17, 2009 9:29 am
pretty sure my tension rods are the culprit. I installed new tie rods, swaybar end links and tension rods all at the same time. makes a knock/clunk every time there is a sudden forward/backward weight transfer, like at a slow roll tapping the brakes makes the noise the worst. I've had the front end in the air to shake pull and bang on everything to see were there is some excess play. the tension rods are the only component that sound loose when tapped with a dead blow hammer.
There seems to be too much play in two areas that concern me, each can be fixed for close to the same price. I can replace either the front power brace or the rods.
I don't know what kind of tension rods I have b/c they were given to me with the car, but there adjustable with spherical ends, they're the tein green color but I don't think there tein's. tThere's some play at the spherical end where I can hold the ball part and it taps as I pull it up and down. There is also quite a bit of play where the front bolt goes through the front brace. Anyone know how much play is normal and which might cause all the noise. Thanks in advance and sorry for the long post
