Jesda wrote:Oatmealman wrote: This is not even remotely true,they can be done in the car,yes it makes it easier to do out of the car but it is not required.3K for a head job? jesus are you going to god himself for this stuff? Most subaru guys report under 1500 for headgaskets,coolant flush,oil change,and a timing belt with water pump.
If you find a cheap and trustworthy local specialist, sure, but typically the engine
will be removed by most shops and you
will spend up to 3k.
Well this is true.I do live within an hours drive of two of the best Subaru specialists in the country.Colorado is kinda a Subaru haven and there are trustworthy subie guys on every block.
