smockers83 wrote:Prelim results are ready, which are probably the ones most of us will want.
I found that using the total miles traveled and total fuel used, using 87 rated fuel results in a MPG rating of 23.91. Using 93 rated fuel results (91 included as 93 assuming the rating compensated for elevation) in a MPG rating 24.57.
Octane - MPG87 - 23.9193 - 24.57
The total miles driven was 10951 and the total amount of fuel used was 456.268 gallons.
So, ultimately, it is cheaper to use regular, but at a cost. You get a worse MPG rating, which causes you to use more fuel. If you're looking to reduce your carbon footprint by using less fuel, thus oil, premium will be your choice of fuel. But if it's money you are looking to save, regular is your fuel of choice.
Where did you get the 10k miles? When I do the numbers I come up with:
91/93 octane 1618 miles / 65.863 gals
total cost - $123.058
mpg - 24.56
per mile 13.148
87 octane 1282 miles / 55.09 gals
total cost - $98.81
mpg - 23.27
per mile 12.974
91/93 octane 12000 miles x 13.148 = $1577.76
87 octane 12000 miles x 12.974 = $1556.88
A couple of other factors come into play however if you try to use a 12000 average for someone other than Telcoman. I brought up the average mph since if you are a high miler you most likely will be driving more highway miles, a low miler - more city miles. How does the average mph affect average mpg for the various fuels? I have a feeling that it is not simply linear
Second and I can only make an assumption here is that the higher octane run was made during slightly warmer temperatures. With my 'G' an increase in temperature helps my mileage although this may not be the case as it gets warmer still. However I do notice a difference between about 30-40 and 40-50. This may be skewed though by the average mph driven during these temps.
As far as the carbon footprint, that is a good point but you also need to consider a therm. For a worker how much longer do they have to work in a job with a higher carbon footprint? What is the carbon footprint of fuel production between the octanes, delivery, etc.?
Then of course maybe the factor of maintenance, does a lower octane few used by Telcoman cost more in maintenance (for Telcoman)?
Also for these figures don't we really need to consider the first load of 93 at the 87 average cost since that is what we are replacing in the tank? The same with 91 when going from 93? The same with total miles? You may have travel x number of miles when you filled up with 93, but those miles were done with 87 octane in the tank? Or did you do that, I'll have to run a second set to see if that was the case.
Perry
