pfarmer wrote:
No I think that was not his point. That is you have his driving record in different months and in different locations. He mentioned his wife since those are the exceptions that needed an explanation. And further keep in mind that it appears that she was driving those short trips within Florida during a timer period encapsulated by other trips within the state.
As far as the temperature thing I believe that the parasitic loads may change somewhat. I don't know what the difference is in flow restrictions between the radiator bypass mode versus the radiator, maybe none so it doesn't come into play for water pump parasitic load. If you have an electric fan, that is a parasitic load that would change with temperature. Average miles per hour most likely change to a certain extent, and my experience is this will change your mpg a lot regardless of temperature. So while the temperature itself isn't the direct factor, the average mph (based on that temperature) you are driving is. Consider A/C as well when it comes to ambient temperature. Depending on your location many drivers simply turn it off. This has some effect, but depends on how often it would engage anyway. In my area A/C is in use at low temperatures for defrosters.
Lots of variables but we are fortunate in this set of samples in that we have a particular owner who keeps good records and drives under different conditons.
Perry
Modified by pfarmer at 10:46 AM 5/5/2009
Perry
My point was to show the effect of short trips and how it reduces MPG as compared to highway driving.
Date Mileage miles Trav Gal Price MPG Total Paid Notes
4-Jun-07 29749 200 11.85 $3.07 16.87 $36.50
Wife using vehicle for local trips in Fl
9-Jun-07 29970 222 11.81 $3.06 18.79 $36.25
10-Jun-07 30382 412 16.21 $2.89 25.41 $47.00 Ga
11-Jun-07 30787 405 15.42 $3.04 26.27 $47.00 NC
Near Va border
12-Jun-07 31200 413 15.13 $2.85 27.30 $43.25 EB NJ
While in Florida I do a lot of walking. The wife drives a mile or two to the fitness center and short trips for meals. This is clearly shown by the drop in MPG while we are in Florida. We fiiled up in the evening of 9 June 07 and left Florida the following morning reaching the Georgia border before filling up again. Notice how the MPG increased from 18.79 from the short trips while in Florida to 25.41 MPG between Florida and the Georgia state line where btw gas is much cheaper than in Florida.
It is clear to me and has been for many years that the use of regular 87 octane for long distance driving is fine. I believe this test with the three grades of gasoline will prove this out.
In my opinion if you run a G on cruise control for a few hours at 65 to 75 MPG anyone else should be able to obtain similar results
My daily 50 miles commute is usually on cruise control on the way in and rarely on the way home as there is much more traffic.
Telcoman
