Which magazine did you see that in?
Dori Dori wrote:From the little Japanese I know, I'm would say 'Tee-en' or 'Teen' because 'ti' in Japanese should sound like 'Tee' and the 'e' and the 'n' should sound like 'en'.:peace
What do you currently have your HE's set at? Is the lowest setting overly bouncy?HighwayStar22 wrote:For daily use HE's might be a bit much. But like it's been said, It all depends on how stiff you like it. I like a stiff ride and the HE's give me that, but by no means is it unbearable, especially if the dampening setting is on the lowest level.
Dori Dori wrote:To end the aluminum/not aluminum discussion, I wrote Tein an email asking what they were made of and here is their response (I also asked if they were monotube like the RA):
Dori Dori wrote:A little advice too...before you order those lighter springs, call Tein and make sure you know what the minimum is. I know some manufactures don't recommend going any more than 1kgf/mm under the pre-selected rates. Also, I don't think the lower spring rate will make too much of a difference. I could actually make the ride worse depending on how the dampers are valved. Anyway, good luck.[/url]
BadMojo wrote:One more question...the springs on the Tein's with threaded bodies aren't pre-loaded, are they? Can I assume this means that they're installed with the spring snug and *not* compressed? Not having to use a spring compressor would make the whole thing really easy.
