Good start would be to get some comrpessor maps and do a little math. For the life of me, I have yet to find any comrpessor maps for any DSM/GReddy turbo's to see how they would do...
Going off my calculations, and what I am seeing here gave me the exact same conclusions good enough for a freshman effort on the RB. The T3/T04E 50trim .64A/R seems to be a very good choice. The only thing I don't know, is the variable efficency that the RB25 has, which would effect top end airflow. I have read the exact same turbo on an old I-6 out of a 280Z suffered from top end, resulting in the drop off of HP and Torque since the engine is trying to scavange exhaust out of the cyl. after 6krpm. The VG30DETT has the same problem on the stock turbo's also. If you see a dyno off a Z, you will see it's powerband fall flatter than a pancake after about 5600.
Making the A/R over 80 would be a good decision IF the VE of the engine is below 85%. Somehow, I doubt that but I don't know for sure.
I also asked Sydneykid over on the SDU forums, guy knows his stuff. He suggests this turbo over the T3/T04E:
We use this Garrett GT25R spec for around 400 to 450 bhp.
0.86 a/r Turbine Housing0.70 a/r Compressor HousingWatercooled Centre48 Trim Compressor Wheel47 lbs/min Comp Flow76 Trim Turbine WheelInternal Wastegate
Based off the maps available on Garrett's website, and his real world experience with the turbo itself, it is very feasable to get around 400HP at 20PSI on this turbo with almost no top end loss on this ballistic series turbo.
These choices in turbos are almost even in spool time, which would kick in around 3krpm.
If you can get your hands on the compressor maps for the TD/DSM series turbo's, I would be more than happy to see what type of output you can expect on the turbo doing a lil math. Hell I would want to know if it's a better option too before I buy my turbo ...
::Correction:: VOLUMETRIC efficency, not variable
