candela »
https://forums.nicoclub.com/candela-u13584.html
Tue Apr 06, 2004 5:17 pm
are these To4B, to4E and to4S not compressor housings... The wheels you use in those certain comp. housings are what make the difference, is this correct? I know the to4B is junk...
I have used a To4E (4" inlet) w/56trim comp wheel, 76trim hot with a hybrid turbine housing (ported 7cm mitsu).
I agree with Redliner, with all the different settups you can use, swap and rebuild with a T3/T4... I think thats probably the best way to go. I think a To4S 60-1, stage 3 .82 would be one killer turbo for that motor.
