Tap Water or Distilled Water in your cooling system?
Tap or Distilled?
Tap
3
38%
Distilled
5
63%
Total votes: 8
OEM
Do you use tap water or distilled water in your cooling system? I have a friend that REFUSES to use distilled water in his sytem because "it makes no difference."
Your thoughts?
moso
Car: 89 240sx ka24de 5spd
90 240sx ka24de RIP
it makes no difference. the only use for distilled water on a vehicle that i know of is in serviceable batteries.
allenms240
Car: 1991 Nissan 240SX
No, it serves a greater purpose.
Tap water is often hard water (contains Calcium, iron, and other metal ions); it is not pure H2O and therefor contaminates your motor, water pump, heater core, and radiator. That's why it can get really dirty in older cars because people tend to use hose water.
Distilled water is de-ionized water, that is, there are NO ions in it except for hydrogen, and oxygen (H2O). It has no contaminants and that why people recommend using distilled over tap water.
I use tap water because, while it does contaminated the motor, I don't plan on keeping this motor forever. When I put in my fresh motor, I will most likely buy a new radiator and use distilled water to keep it clean.
Dimitri
Car: 1990 240SX Red Hatchback-
Oui c'est un 240sx et non ce n'est pas à vendre
I can see why tap water will be "preferred"; it's "free" and easy to get (just bring over the hose).
Distilled water, costs money AND you have to go to the store to get it.
After seeing how badly tap water scaled my coffee maker, I wouldn't want it anywhere inside my car :)
I buy the premixed coolant when I do a drain and refill. Never considered using "plain water" :)
moso wrote:it makes no difference. the only use for distilled water on a vehicle that i know of is in serviceable batteries.
Not true.
Ever seen an aluminum radiator with tap water after a year?
I run 80% distilled water, 15% coolant (not pre-mix, it's a ripoff), and 2 bottles of Water Wetter.
Using too much coolant is a waste of money as well. I've seen knuckleheads put an entire gallon in their radiator... :facepalm:
IanS
Car: 2002 Subaru WRX, 2010 Subaru Forester XT, 2004 Infiniti G35 Coupe.
Wish I could do that. Stupid freezing weather.
Seriosuly, Distilled water is $0.98 a gallon at Cub. I have seen what tap water does to engines. Its cheap insurance.
asoomal
Car: 2001 Subaru Impreza L 5MT (Daily)
1992 Nissan 240SX SE 5MT w/HICAS (Being restored)
Tap.
Vancouver water ftw.
