Talk to me about drum brakes...
oldandslow
Car: 08 G35S & a bunch of fords
You might not have to take anything apart to inspect the pad thickness.The backing plates should have inspection holes in them.They are usually covered with a removable rubber plug.
USAF_G35_Guy
Car: 2003 G35 Coupe 6MT
When you get all finished, take some mental notes of the overall process just in case you decide to change your rear axles on the G someday or decide to take your rear rotors off for any given reason. Cause you're parking brakes are basically drum brakes as well, and sometimes, their disassembly is required to do other things to the rear suspension/drivetrain/brake assembly. There's also the possibility that you may need to actually change them, but you'd probably have to pick up drifting for them to wear down They also have a little hole with a rubber insert to look in and adjust the parking brake pads.
If you do try and look inside the drum to view the drum pads.....remember a flashlight
+1 on before pics and good luck!ah...also +1 on the beer!!!
gwoods
Car: 2013 Infiniti M37x
1999 Nissan Altima SE limited 5spd
1992 Miata (soon to be turbo)
1965 Cj-5 with 327 v8
2012 Toyota Sequoia Limited
you talkin about these drum parking brakes??? I doubt you would wear these out unless you are into drifting hard core
Sentientbydesign
Car: 03 Evo VIII - 330 AWHP
05 Subaru Legacy GT Stg 2 - Sold
05 G35 6MT Coupe - 278 WHP - Sold
04 WW Evo VIII - 302 AWHP - Ex's
96 I30 - Sold
gwoods wrote:you talkin about these drum parking brakes??? I doubt you would wear these out unless you are into drifting hard core
Thanks guys! I would have never known we had drum parking brakes (until I replaced the rotors). I've been kind of fearful lately when I engage the parking brake because I thought it would warp my rotors (after spirited driving).
gwoods
The Hemi Ram has the same set up I mic'ed mine when I had the rotors off and they were almost like new after 27k miles. The sedan doesn't have a hand brake though so it would be dumb if they were worn at all
USAF_G35_Guy
Yup^^^ those be the one's Jeff ....and ya, it would take some pretty heavy driftin to wear them babies down. The parking brake pads would probably last the life of the car....as long as they weren't engaged for a long period of time while the car sat and then corroded/rusted themselves to the inside of the drum haha, but other than that...should be good to go!
BigWill
Car: Gone, but not forgotten-2004 G35 Coupe-5AT-Graphite Now-2008 Black Saphire IS 250
rn79870 wrote:What say you BigWill, more pics?
Absolutely!! I'll start things off...
Sentientbydesign
96 I30 - Sold
Is that a ForTwo with a body kit and an asian stripper?
SVTCOBRA
Car: 2018 Q60 AWD 2023 F150 4x4 5.0 FX4
^ looks like a Shelby body kit on it!
gwoods
body kits are good for what 100 hp? racing strips ad 50 hp? 5hp added for each peice of HEAT trapping chrome?
groundrocket
Car: 03 G35, 97 Nissan Pickup, 67 Mustang, 66 Ranchero, 78 Spyder, 94 CBR900RR
gwoods wrote:body kits are good for what 100 hp? racing strips ad 50 hp? 5hp added for each peice of HEAT trapping chrome?
So the stripper is worth what? an extra 8-12 psi of boost? oh... wait ... that would be a blower...
