Just discovered about the CA18DET and read alot about it, went through all pages in here. Everyone says that a T3 is going to be laggy and not worth it on a 1.8liter. But i haven't saw any facts saying i boost X psi at X rpm on a T3... or maybe a very little and already forgot about them! So anyone running some T3 setup could hook me up with these? By the way, if it spools a bit later, wouldn't a set of good cams and maybe a little valvetrain works be enough to rev it a little higher and still get a very nice powerband?
Also on DSM and Honda Holsets are very popular, cheap and reliable! And they are using them on there 2.0L, 1.8L and even some ppl uses them on there 1.6L and seems to be happy with the spool they get. I'm looking at the HX35 mainly, most common one and easiest to come by. On Honda-tech some people see around 15psi a bit over 4k rpms on 1.8L, would u consider this laggy on a 1.8L? And that HX35 has a twin scroll housing that i would benefit by making a twin scroll manifold to get a better spool. (Anyone already experienced twinscroll/normal turbo spool difference?)
So my goals are to have about 300whp reliable. I was mainly thinking going on a KA-T with that holset until i found out about this motor. Sr20 is just to much money for what i need if i can get done cheaper with this motor! And this seems to be more reliable than a KA-T with stock forged internals.
I've read alot and saw most answer that T2 flanged (Gt28r, Gt28rs, T28 etc.) can get the job done. That's not the answer i'm looking for please! This would be a DD so lag isnt an issue as long as i have a good powerband in the upper rpm, it would even be good so when cruising around its just like a stock 1.8L.
Btw Dee would be nice if u could send me an email at
[email protected], would be nice to talk a bit with you about this motor
P.S. sorry for such a long post, but i took my time and shouldn't be to hard to read!
