themadscientist »
https://forums.nicoclub.com/themadscientist-u2806.html
Wed Jun 25, 2008 3:52 pm
no, I mean you are doing what just about everyone else here does, concentrating on flash parts and wasting money. YOU ONLY WANT 300 HP!
Do a good rebuild with quality machine work, by this I mean.
hot tank the block
bore and hone to your pistons
have deck checked and corrected if needed on both the block and head
check the valve guides, likely replace them, bronze is nice but not required
if you want a braggable part get some rods, not required for 300 but not a waste either
go with some nice pistons, braggable and lighter, take some rotating mass off
have the whole set dynamically balnanced so it spins with no vibration
new oil and water pumps
stock cams are fine for 300hp, 256 would be better, 264 a bit too much
adjustable sprockets and have the cams degreed straight up
stock timing belts are fine if changed regularly but a kevlar on is good insurance
new oem gaskets all around with a metal one on the head for a little extra
ditch that ****ing 20 year old computer and get a standalone. (yes boys and girls, the CA18 computer is TWENTY YEARS OLD. the AFM is tiny and restrictive, it has a boost cut, a speed cut and the processing power of one of these!)
Now get some fuel, a 255 walboro drop in pump and at MINIMUM so clean 550s but 600s would be better, stock rail with adjustable regulator.
Keep the oe manifold and slap a nice actuated T28 on there with a nice FMIC and real BOV. That's my way of saying the tweetybird BOV is a joke.
full exhaust with a tubular outlet on the turbo and tune it out.
That flash manifold is money for the fuel pump, potentially the regulator.The smaller ports in the oe manifold fill up quicker and will thusly spool the turbo quicker but will choke at higher RPMs (read sustained WOT like drag racing). You and about a million other people care about that, I don't. A tubular manifold is good for me because I do mostly roll ons and top speed work where lag is not noticeable at all. I also lean towards larger turbos that are in their element flowing at the top rather than around town drivability.
