T3 GT35R on Stock Mani?
FinkenS14
Car: 1995 Nissan 240sx S14
Will it work in an S14?
eh?
I don't know but you can always build an adapter box like this:http://cgi.ebay.com/ebaymotors...ories
I had a little t3/t4 50 trim and the compressor housing hit the manifold. I used T3 flange to space it out but I don't think you'll be able to do that with the GT35R.
DrifterProdigy85
Car: 1989 Nissan 240sx (Zenki Onevia)
Hmm. This gives me a good idea for putting a 2871R on mine.
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
Even if you went with an internally-gated turbo (lame idea on a 35R, but possible), you'd still need to space the compressor out from the manifold at least 1/2", maybe more depending on how the compressor is clocked.
Funktown240
Car: 93' 240sx
eh? wrote:I don't know but you can always build an adapter box like this:http://cgi.ebay.com/ebaymotors...ories
Does anyone build a t25 to t3 adapter with a WG flange on it that you know of? It would be better on the top of the adapter rather on the side as well, does anyone on here run a similar set up like I described? I just cant justify spending 1k on a mainfold, when I could spend it on a badass turbocharger :-)
Darius
Why not step it down to a more responsive T3 turbo like a 3076R with internal gate? Let's be realistic here. You're looking at a 35R with more capacity than the stock bottom end. What is the point in anything bigger than necessary unless you like lag?
Funktown240
Car: 93' 240sx
The gt3582r only has a couple of hundred rpm's more lag than the 3076, so why not get the bigger turbo and make the same HP with less boost. I have heard that you cannot tell the difference in lag between the two. Believe me I know about lag. . . . . .I had a PT67 on a 1.8 liter Honda motor, wouldnt start to build boost till 5.5k rpm-but when in boost it was INSANE!!
eh?
So why do you want the t25 adapter?
Funktown240
Car: 93' 240sx
So I can use the stock manifold. . . . .
ItzGenX
Car: Smoke Purple 95' S14.5. Powered by the "Iron Man".
Why not use a stock RB25 manifold? I am assuming you are running a RB20. The RB25 manifold should work on both motors and is T3 flanged.
GSDKinked
Car: 1997 240SX LE
ItzGenX wrote:Why not use a stock RB25 manifold? I am assuming you are running a RB20. The RB25 manifold should work on both motors and is T3 flanged.
I am running into the same issue. And he wants to use the stock mani, its just that the compressor housing hits the manifold and wont allow you to mount it. Plus there's the issue of clearance bottom mounting it. I'm wondering if I can do it in my S14.
Cjmartz2k
Car: Hunting for a '89 GTR now
Funktown240 wrote:So I can use the stock manifold. . . . .
Except a stock RB 20/25 manifold is T3............
FinkenS14
That thing is SICK!
placham
Car: 1992 Geo Prizm (4AFE)---Gone
1990 Nissan 240sx Coupe (RB20DET powered),
1994 Toyota Celica GT (3SGTE swapped), 1995 Nissan 240sx KA24DE,
2011 Nissan Sentra SER Spec-V
okay
Cjmartz2k wrote:Except a stock RB 20/25 manifold is T3............
+1 on T3 flange
Funktown240
Car: 93' 240sx
Woah, I didnt know that! Still learning a little- this is my first Nissan, I got a RB25 swap BTW. Whats the biggest turbo that you can mount to the stock mani and still clear?
Darius
GT55R dawg!!!
I'm telling you, 3076R will beat a 35R on a stock RB25 any day of the week.
Funktown240
Car: 93' 240sx
Darius wrote:GT55R dawg!!!
Thats not big enough, I want something bigger!! :- P
Darius
On a stock, log, T3 manifold on a stock RB25 bottom end? Makes perfect sense to me
boosted98gst
Your wanting a big turbo and worried about spending 1k on a proper manifold? I think you are in the wrong game.
Darius
It's understandable. He was a Honda guy so it will take a while to work all the underglow, supra wings, and VEEETAAAAACKK out of his system
Just kiddin' ya hahaha
virus77
Car: 95 S14, 71 240z, 97 e320
Here's a 60-1 we installed on my buddies s14, no spacer but we shaved the manifold and turbo slightly for clearance. A t3 flange as a spacer should work good with an internal gate 3076r...
GSDKinked
Car: 1997 240SX LE
But it would have to be T3 to T3 and not T3 to T4
Blown240sx
Car: 1996 240sx
My buddy ran a 3076 on his with no spacer. Just needed to grind down the exhaust manifold a little.
Funktown240
Car: 93' 240sx
Blown240sx wrote:My buddy ran a 3076 on his with no spacer. Just needed to grind down the exhaust manifold a little.
Hmmmm. . . . .my buddy has a gt3071 laying around. I should persuade him to let me borrow it LOL
FinkenS14
Darius wrote:It's understandable. He was a Honda guy so it will take a while to work all the underglow, supra wings, and VEEETAAAAACKK out of his system
I hope your not talking to me
EVILS14
Car: 1995 NISSAN 240SX SE RB25DET
easy guy it was just a joke
Blown240sx
Car: 1996 240sx
We made 363 whp on 16 psi on his with a few bolt ons.
DrifterProdigy85
Seeing the manifold only needs shaved a little to clear a 30r, would a 2871R fit up without modification? Im not sure how much smaller the compressor housing is compared to a 30R.
Darius
haha lighten up Francis! It was completely a joke.
Blown240sx
Car: 1996 240sx
3076 on my friends car.
