SRMUNKY wrote:anyone know if my turbo is salvageable?i was driving up in northern Ontario, and i blew my manifold-turbo gasket,
If you are talking about your 4 bolt turbo inlet gasket then that could be the reason you are not getting any boost. All of your exhaust pressure is leaking out of there and not spooling up the turbo. It should built a little boost though. If you change that gasket between the turbo manifold and the turbo then you should be fine. Rarely will a turbo just fail like that. You might also have a big enough peice of that gasket material stuck in the tubine wheel of the turbo causing it not to spool, but doubtful.
If you still wanna rebuild it then you can call a place called Limited Engineering (928-453-7321)and they can send u a rebuild kit or you can send it to them to get rebuilt.
