SpeedRacer1 »
https://forums.nicoclub.com/speedracer1-u311.html
Sun May 08, 2005 5:06 pm
The front housing of the T28 would probably fit on a T25. But there is no benefit I can think of, only negative consequences. The compressor inlet and outlet pipes are turned the wrong way from T25 pipes so that would need to be fixed. The wheel on the T28 is larger so if you put it over a T25 wheel there would be a large gap and it would mess up the efficiency of the turbo.
Difference between S14 and S15 T28's, different material for wheels, and a cast divider between the wastegate and the turbine wheel.
Exhaust housings would be practically useless to change because other than the cast divider they are the same.
