Grant@tirerack wrote:I'm assuming this is on a '95 model from your signature. The stock tire size of 215/65-15 is rated for 1378 lbs. when inflated to the stock 29psi..
Which is why no knowledgeable Q45 owner runs them at that low of a pressure. The static load with half a tank of fuel and just the driver is 1200 lbs. on each front tire, so dynamic cornering and braking loads are even greater. It's still a dicey proposition to mount tires of less load carrying capacity than OEM because OEM specifications are the minimum specification that the manufacturer believes will function on the car. This is doubly true when the car weighs two tons like the G50.
Which brings up a question I have always had: How can most tire retailers claim OEM suggested pressures are sufficient when the maximum loading occurs at higher pressures for newer optional tires than for OEM tires? 29 lbs. psi on a tire which achieves maximum load capacity at 36 psi is a lot different than in a tire that achieves it maximum load capacity at 51 psi.
Also, is the load carrying capacity of a tire roughly linear across it's operational range (say OEM minimum to load capacity maximum pressure)? For the OEM tire cited above, (29/36) X 1521 = 1225.1 lbs. (the static load!) Quite a bit less than the 1378 lbs. @ 29 lbs. psi cited above.
Would you comment on the decrease of load rating of the Firestone SZ 50 EP I mentioned before? Is this a misprint or documented by testing? And I don't really understand why TR doesn't specify the correct 255/45 - 17 tire for the G50 Q45 when it is availble at essentially the same price.
As far as the wheels which TR carries, unless I am wrong, only the SSR and some BBS seem to be forged. Centerline does list a load carrying capacity on each wheel they sell, but they do not state how they arrive at that figure. TUV is a uniform standard, but I wonder if they test on a lighter car, or on a laboratory jig? Surely they must accomodate the big Mercedes and BMWs in their procedures.
Does TR test each wheel for OEM specifications for run-out and balance before mounting the tires when they are purchased as a package?
Thanks for sharing your knowledge.__________________Brian1995 Q45 & Q45t
Discover the power of the button!
