Synthetic Oil
Andy_V35Sky_350GT
Car: 2003 Nissan Skyline 350GT
EXCELLENT info, like you I've been using Mobil 1 extended 10w30, never had any issues with this oil.
SVTCOBRA
Car: 2018 Q60 AWD 2023 F150 4x4 5.0 FX4
szhosain wrote:
FWIW, I do 3750 mile changes on my oil and filter. With Mobil 1 Synthetic 0W-40, yes, but I believe I would be just fine doing this with a good dino 5W-30 oil (like Castrol GTX or Chevron Supreme), if I was concerned about the cost of the synthetic.
Z
So, you're not doing syn to extend the time between oil changes.Is it safe to assume you use syn because you believe it's better for the engine's internals?
I also change my Mobil 1 Syn between 3K & 4K and use it because I've heard that my engine will like it better. less wear & more HP
Q45tech
The 2nd and 3rd/4th owners of your cars will really appreciate your thoughfulness and kindness.
Just as many of us have learned to appreciate the JDM junkyard engines for the quality of Japanese oils and frequent changes and maintenance they receive.
US oil and poor consumer mainteance can always be FIXED by swapping an engine.
Whatever oil you use has a hard time overcoming 20 years of ABUSIVE cold cranks.
szh
Car: 2018 Tesla Model 3.
SVTCOBRA wrote:So, you're not doing syn to extend the time between oil changes.Is it safe to assume you use syn because you believe it's better for the engine's internals?
Correct!
SVTCOBRA wrote:I also change my Mobil 1 Syn between 3K & 4K and use it because I've heard that my engine will like it better. less wear & more HP
I don't know about that more HP bit though!
Z
abdoman
Car: 2006 G35
The recommended oil change interval for my 06 is 3500 mi on dino, not 7500 mi.
clmays1
Car: 2003 G35
I would always run synthetic. Mobil 1 is not a true synthetic, but it is still a great oil and better than any conventional. The local wal-mart here in NC does now sell Royal Purple street formula.
