syncromesh over royal purple.
DarkBlueSr240
I have Royal Purple in my sr trans and it grinds second gear. People are telling me to put in syncromesh in I donno what do other people run?
CoupedUp
Car: 1993 Coupe
I dont know if "new" oil is gonna remove a grind. It might mask it.
Personally theyre both great oils just personal opinion.
DarkBlueSr240
it never used to grind and now since this is in it seems like it started to.Someone said that its to slippery and the syncro's aren't slowing down enough...
CoupedUp
Car: 1993 Coupe
You put it in and then it started? I thought you meant after a while.
Theyre both oils, if you dont mind spending the money. Try it out. Synchromesh may give you a better viscosity.
DarkBlueSr240
I already have the royal so I mise will try the syncromesh i also have a b&n shifter.....
jubee
Car: 92hs13
i would not put Synchromesh in unless you wanna getting a new transmission.
IanS
Car: 2002 Subaru WRX, 2010 Subaru Forester XT, 2004 Infiniti G35 Coupe.
what wieght are you running, you can just grab any random viscosity and put it in royal purple makes lots of differant kind of oil, are you sure you got the right one
DarkBlueSr240
Ill have to go look what kind should i put in. the v8 guys told me to put in type f auto trans fluid.
IanS
no no no no no
80w90 gear lube or 75w90 gear lube
atf is for automatic transmisions, get that stuff out of there, and tell your V8 buddies to go drink some leaded 82 octane
DarkBlueSr240
alright ill go for that stuff. I knew the atf stuff just didnt know if I should use.I will try the other stuff and let you know.
jubee
Car: 92hs13
I use Valvoline 80W90 cheap stuff in my transmission and it's great. Others swear by Redline MT90. Either one will be good for you.
IanS
I run amsoil 75W90 syn
ZL-Auto
Car: Zerolift Autolab - 513-874-2508 - [email protected]
Redline MT90 or Amsoil 75-90 is great too.
spider_slayer
Car: S14 240SX
S13 240SX
i forget where, but i think i remember reading that the syncromesh will wear out the trans prematurely.
anyone care to back this claim up with proof?
SpuGen
Car: 1992 240sx SE
Try mixing GM Syncromesh with some Redline Shockproof. I've heard that 2 parts Syncromesh and 1 part Redline works great for honda trannies, so maybe try 50/50?
C - ROD
Car: SR20DET pignose hatch
its the GL rating that makes a difference, all of the fluids u guys are listing are a GL-5 rating, when the nissan trannies require a GL-4 rated fluid, when not using the GL-4 fluid, u chance wearing out the syncros prematurely, nissan says nothing but GL-4 should go into thier trannies!it took me about 6 months to figure this out after i toasted my sr transmission. it started off as a grind then it started not allowing me to shift into 2nd, then 5th i was running mobil1syn. GL-5 so i had to swap it out for a KA with the SR bellhousing on it, i got this stuff from my work that is made by BG, its rated at GL-4 80w90 so that is what i use now, i dont know if everyone can get this fluid or not, we get it thru a dealer who comes by our shop
URAS
Car: 550hp RB26 in S13 and 450hp rb25 in R32
Redline shock prrof in the lightweight is the be all and end all for SR gearboxes. run an extra liter and extend the breather up to the firewall.
MOTUL gear 300 is a close second, i dont rate royal purple.
