Well, I have a ball bearing turbo that uses a lot less volume of oil if that makes a difference. Also, I have the factory oil cooler. What do I do??? BTW, I've been using 10W-40 conventional oil so far.Kouks wrote:I would go with 10w-40. The second number in the "code" is the weight when the oil is hot. 30w is not thick enough oil for a turbo car to function and lubricate properly the turbocharger and valvetrain. 30w is for n/a engines, and s/c.
With an oil cooler, I wouldnt mind hinting at the 10w-30, but without one, go with the hot 40 weight.
Please recommend something to us oh wise and worthy master? And tell us what's so way off base of running say a 10w30, a 10w40, or a 0w40 please? I expect to see some UOA findings as well.Nowhere wrote:ignore the link @ the bottom for the bitog (bob oil guy), read the 101, 102, 103, etc, etc....
He needs to go with the oil the ENGINE needs...
my 2 pennies are staying in my pocket.
wow i read it, learn something new everyday your oil pump cant create the same oil pessure at the same rpm's with a thicker oil hence not enought lubrication and fricton incures robbing your power. a 0-30 wt oil will thicken less at room temp so when you start your motor you have more lubrication. and a 10-40 wt oil will not create the required oil pressure at the same rpms for nessisary lubrication at operating temps. remember flow equals lubrication, not weight. for the rest I'll let you read it!Nowhere wrote:omg you guys have no idea what you're talking about....
READ THE WHOOOOOOOOOOOOOOOLE THING!!!!!!!!
http://63.240.161.99/motoroil/index.html
I too like some thickness! I've always used a 20w-50 oil whether it was Castrol syntec blend or greased lightning, the amount of wear on my engines were minimal. Look at it like this, turbo engines dirty-up oil in a quick fashion which makes oil a throw-away fast product, if oil changes are done on time. Why waste the money? You can even use catrol's gtx oils as long as you change the oil frequently. Your driving habits warrants when you should change your oil. If you're an abusive driver, change your oil every 2000 miles. You guys get where I'm going with this as I'm not an oil expert, but I do know what I've used in my cars over the past 16 years and 20w-50 syntec blends seem to be the best for the climate I live in and the way I drive.Kouks wrote:Its about to go cool c-rad here in florida, so I say run it, 10w-30 mobil 1 syn. If sean can run it, so can you. i like a little extra thickness for when it gets hot though, but i might have to try the 10w-30.
You are aware that compressed air is usually 77% Nitrogen right? Also Nitrogen isnt that much lighter compared to Oxygen.BACARDI_DWB wrote:i fill my tires with nitrogen! costco uses that instead of normal air.(its lighter)
