Thats about as helpful as a hole in my head hahahahahahnnorton44 wrote:http://www.phoronix.com/scan.p...num=1
This is the kind of advice I'm looking for.Adeianos wrote:If you're using a Laptop, I wouldn't recommend Fedora, as, in my experience, Fedora has been lacking in out of the box driver support. I use OpenSUSE on my server, and it works wonderfully for me. Ubuntu works well on laptops and is a good system to learn on if you don't have much Linux experience.
Just remember, you can use WINE (http://www.winehq.com) to emulate windows, which should help you run programs that don't support Linux.FlatBlackIan wrote:
This is one more skittle in the bowl on Ubuntu's side. Im leaning more in that direction anyway, it seems like the user base is larger, and support more available.
Im also trying to find out how many tuning programs support Linux based systems, as I will use my laptop for occasional tuning.
This is a thought Ive kept in mind. Im still just running through options, I'm just feeling the need to step as far from Microsoft as possible as of late.rawill240sx wrote:Or you could leave windows as the primary OS, and load vmware and try as many different Linux flavors as you want.
http://www.adeianos.com/Emulators.rarFlatBlackIan wrote:
On a slightly related note, does anyone have an emulated version of Mario 3 for NES.
Ive been craving as of late, and my copy of Super Mario All stars no longer works.
Can you clarify "bloat"?PoorManQ45 wrote:Go with Ubuntu 8.04 instead of 8.10
The newest version adds a good bit of bloat
Has a few hundred games for both NES and SNES, along with both emulators.Enjoy.
It had to do with the partitioning of the hard drive. I did the partitioning using the windows drive manager, and just left open space for linux. After installing Ubuntu XP decided it would not accept any of the partitions except the tiny one it was based in. I had no file storage. I reconfigured the main file storage (shared) portion of the drive which should have been fine, but I ended up with grub error after error. I didnt want to deal with force loading, so I started all over, and dropped XP entirely. I had already dumped all my important files to my external HD anyway.PoorManQ45 wrote:That's weird.
Grub natively integrates XP and/or vista into its bootloader.
Sounds like what happened was you confined XP to whatever it was using at the time of the re-partition. When you installed Linux it took over the rest of the HDD and had it formatted for Linux. Windows can only "see" certain formats of Linux file system so most people have three partitions for a dual-boot. You have the XP partition, the Linux Partition, then the Linux-Swap Partition which is a file system both OS's can see.FlatBlackIan wrote:
In the event that I do need windows for something (doubtful) I can always use my wife's computer.
Im going to see how long I can go without resorting to that.
Thats how I set it up. I manually set up the partitions, and when I installed linux I didn't format the shared file storage part of the drive. I left it unformatted until I had both OSs loaded. Then I tried to format that portions, using a Windows filing system. For some reason the Windows drive manager decided to mess with the boot loader.Maverick7687 wrote:Sounds like what happened was you confined XP to whatever it was using at the time of the re-partition. When you installed Linux it took over the rest of the HDD and had it formatted for Linux. Windows can only "see" certain formats of Linux file system so most people have three partitions for a dual-boot. You have the XP partition, the Linux Partition, then the Linux-Swap Partition which is a file system both OS's can see.
