ILoveMyRHS13 »
https://forums.nicoclub.com/ilovemyrhs13-u75554.html
Tue Oct 20, 2009 6:35 pm
Okay, it's been a while, so I figured I would update you guys.
Last friday I went into my school to finalize some paperwork. The car was giving me issues on the way up, running on 3 cylinders and other fun things. I figured the injector harnesses were giving me trouble again. I was about to leave my school; the car had other ideas. The car just clicked, and didn't turn over. Immediately I called MGE to try and get an idea from him. His only solution was to push start the car because he wasn't able to be there and troubleshoot. I got the car push started but it would die if I didn't give it constant throttle, so I had no choice but to leave it in the parking lot. A couple days ago, MGE and I went up to look at it and try and limp it home. Turns out, the alternator took a s***; great. So today I bought a new alternator with a LIFETIME warranty, so I wouldn't have any worries. Threw that on and drove it home.
Two sundays from now is the drift school. MGE, Didderson and I will be attending. I'll be repping driftWARFARE, which is started by a local named Damien, which he might attend as well. I'm really stoked to be repping a local club at the same time as learning how to drift.
Before the event I have to:Replace front main seal. We found out it was leaking rather bad.Replace the fan and fan shroud. I had to remove it for the alternator.Fix odds and ends around the car.
My plan is to get the welded diff in the car this weekend to learn how to daily drift and slide around a little bit. I will update this thread as progress is made.
