Of course (from the yard), you'd try and select a NEW TRANS with low miles.
Hey Thanks VStar,VStar650CL wrote: ↑Tue Aug 05, 2025 1:06 pmYou should only trust a JY CVT if you can get the donor TCM along with it. That allows you to hook the TCM to the recipient to make sure there were no judder or other codes in it before it was junked, and in most cases you can leave the TCM installed and circumvent needing to program the IP values. If it reads clean, change the fluid immediately and you're good to go. If it isn't, you can take it back to the JY before you spend effort on a new headache.
I appreciate your input here...VStar650CL wrote: ↑Wed Aug 06, 2025 5:28 amYes, the TCM and ECM are both right next to the battery on most CVT models, if you want to post your vehicle, I can tell you specifically. You can keep the TCM you already have if you want to reprogram the IP's, but that defeats the purpose of knowing whether there's anything wrong with the JY transmission. Only the TCM from the donor can tell you that.
Ahhh... sounds like you've done this before!VStar650CL wrote: ↑Wed Aug 06, 2025 3:32 pmCorrect. There shouldn't be any issues if a scan of the donor TCM is clean, the fluid isn't badly burnt, and you replace the original TCM with the donor TCM as part of the operation.
Pitfalls:.....
Hook up the 'Donor TCM' to the 'Recipient Car'...then read the codes. IF codes come back clean, its good. ONLY then would I move to Step #2.VStar650CL wrote: ↑Thu Aug 07, 2025 5:52 amNo, you're not getting this. You hook the TCM up to the recipient car and read it. If it reads clean, then you go to step two, make sure the fluid isn't burnt. If it doesn't read clean, you take the TCM and the transmission back to the JY and try again.
thanks VStar,
Wow... that's interesting.VStar650CL wrote: ↑Thu Aug 07, 2025 10:49 amThe transmission has absolutely no "smartwork" inside. If the TCM is code-free, then the odds of the transmission being bad anyway are near zero.
That's fine if the JY left everything in the car, but even Pick-and-Pulls usually yank the engine and trans before they block it. However, most junkies record the VIN of the drivetrain parts when they pull them, so if the TCM is still in the car it can be matched up and pulled. Checking for DTC's in the donor car is pointless if the transmission is absent, that creates a whole slew of new DTC's and makes anything but judder codes indecipherable.PapaSmurf2k3 wrote: ↑Tue Aug 12, 2025 6:34 amI would think you could also just take a jump pack or something to the junk yard with you to energize the car and scan it on site instead of taking the TCM home with you, no?
It should save you a trip and a conversation with the junkyard staff.
Ok... you got me... What is DTC ?VStar650CL wrote: ↑Tue Aug 12, 2025 6:58 amThat's fine if the JY left everything in the car, but even Pick-and-Pulls usually yank the engine and trans before they block it. However, most junkies record the VIN of the drivetrain parts when they pull them, so if the TCM is still in the car it can be matched up and pulled. Checking for DTC's in the donor car is pointless if the transmission is absent, that creates a whole slew of new DTC's and makes anything but judder codes indecipherable.PapaSmurf2k3 wrote: ↑Tue Aug 12, 2025 6:34 amI would think you could also just take a jump pack or something to the junk yard with you to energize the car and scan it on site instead of taking the TCM home with you, no?
Thanks V,
I just thought of something... in the above, you'd have to take the DONOR TCM to the 'Recipient Car' and test it on the 'Recipient Car' (with the BROKEN transmission in place) ---- CORRECT ?PapaSmurf2k3 wrote: ↑Tue Aug 12, 2025 6:34 amI would think you could also just take a jump pack or something to the junk yard with you to energize the car and scan it on site instead of taking the TCM home with you, no?
That does create a problem (but still worth the effort); the only solution is 'have a key made' or 'hopefully the JY has it (or its still in the car, on the floor somewhere). OTHER-WISE, a Locksmith would have to make one.---VStar650CL wrote: ↑Thu Aug 14, 2025 12:11 pmIt occurred to me after yesterday's post that testing in the JY is only feasible if the JY gives you the keys. The TCM won't talk with the ignition off. In any case, it will take about 30 seconds on an Altima to pop the TCM connector and connect it to the donor TCM for a code read. So yah, it's probably a big time-waster trying to pre-check it in the JY.
