That's a negative, Ghostrider. The gen5~6 Altimas all have I-Key fobs, not steel smartkeys. If the JY doesn't have the fobs then GFL.
Are you saying you 'can't get a FOB key' for JY car --- I thought YOU could get one with the VIN?VStar650CL wrote: ↑Fri Aug 15, 2025 9:43 amThat's a negative, Ghostrider. The gen5~6 Altimas all have I-Key fobs, not steel smartkeys. If the JY doesn't have the fobs then GFL.
Lets assume there is 'No Key' available at the JY.VStar650CL wrote: ↑Fri Aug 15, 2025 12:39 pmNot with an I-Key. It needs to be programmed to the BCM and ECM in the car before the BCM will allow the ignition to wake up. You need a special scanner and special software for that.
*-Thanks V,VStar650CL wrote: ↑Fri Aug 15, 2025 12:39 pmNot with an I-Key. It needs to be programmed to the BCM and ECM in the car before the BCM will allow the ignition to wake up. You need a special scanner and special software for that.
I'm an amateur ... My Gear Monkey friend is a Retired Porsche/ Audi mechanic (who's pretty dam good mechanic). I WOULD NEVER attempt this without him leading the job...PapaSmurf2k3 wrote: ↑Mon Aug 18, 2025 11:11 amSwapping a transmission isn't really an easy job. Definitely not where you want to cut your automotive teeth. If you don't know the terms ECM, TCM, BCM already, you might be biting off more than you can chew.
Aha, so in that generation the 18s would have the most reliable transmisisons?VStar650CL wrote: ↑Fri Aug 08, 2025 9:18 amOn the gen5 Altimas, for example, the '13's, 14's, 15's, and '18's all had minor differences from one another. The only ones that cross 100% are the '16~'17's, but those had crap Valve Bodies.
Correct.
Definitely better than the '10A/'10D/11E's used with the 4-bangers.
Unless you're made out of money, OEM LED's are an expensive gimmick. When a "bulb" fails you need to replace a whole $1~2K assembly. That's nuts when you can retrofit a halogen assembly with good quality aftermarket LED's for a $tenth of that. In the gen5 Altimas, the reduced heat load from aftermarket LED's also prevents the problem they had with peeling chrome on the reflectors. That issue was strictly heat-induced, and replacing the hot halogens with cooler LED's totally mitigates it.
Super answer thank you so much!VStar650CL wrote: ↑Sat Dec 13, 2025 6:33 amCorrect.
My advice to everybody looking at '10A/'10D CVT Nissans is the same, bring along a dongle and a copy of CVTz50 and look for judder codes (P17F0/P17F1) or overheats (CVT-A/CVT-B greater than zero). If it's code-clean and shows no overheats, call it good and service it immediately just because.
No, I just said China-cheap ones aren't good. My personal choice is Diode Dynamics, because they're not only well engineered but they're the only brand made in USA. However, the technology has made leaps-and-bounds improvements and continues to improve, so even some of the offshore-made brands like Lasfit and Auxito are producing some really good stuff these days.
