wink-rb26dett wrote:Okay guys, I got a complete wrecked R32 GTS-T that I got for very cheap. I got a RB25 on an engine stand and The R32 came with an RB20. I'm planning on putting the RB25 into the 90' 240SX I have. What of any stuff can I use out of the whole car, can be used in the 240? I will be using the R32 front crossmember to mount it in the engine bay but, what do I use for the engine harness? will the R32 transmission mount work? will the R32 gauge cluster work? Will an R32 rear diff mount and driveline work in the 240sx? Need a lil help guys, I'm pretty fresh at this stuff. Unfortunatly I use to be a Honda guy. Damn...Help! Thanks.
Modified by wink-rb26dett at 7:34 AM 12/14/2007
we used a skyline crossmember from the clip in our RB25DET Swap DVDhttp://store.driftingshop.com/rb24sdv.html
this parts list can be used as a reference
Parts List/Source
R33 Skyline Front Clip - (Sr20Store.Com)Syko Performance Rb25 Converted Upper And Lower Harness - (Sykoperformance.Com)Syko Performance Motor Conversion Mounts - (Sykoperformance.Com)Syko Performance Transmission Brackets - (Sykoperformance.Com)Syko Performance Sway Bar Brackets - (Sykoperformance.Com)Syko Performance 1 Piece Driveshaft - (Sykoperformance.Com)Intercooler Piping - (Sykoperformance.Com)Intercooler Core - (Meganracing.Com)Couplers And Clamps - (Hosetechniques.Com)Power Steering Cooler - (Sr20store.Com)S13 91+ DOHC Power Steering Lines And Fittings - (Milano Motorsports)Greddy RB25 Intake Manifold (Purchased From (Phase2Motortrend.Com)Rb25 Intake Manifold Gasket - (Phase2Motortrend.Com)Infiniti Q45 Throttle Body - (Junk Yard)Infiniti Q45 Throttle Body Gasket - (Purchased From Infiniti Dealer)Apex-I Power Intake - (Apexi.Com)Apex-I Power FC & Commander - (Apexi.Com)Apex-I Auto Timer - (Apexi.Com)Flex-A-Lite Low Profile Dual Radiator Fans (#220) - (Flex-A-Lite.Com)Clutch Stage 3 Upgrade - (Specclutch.Com)Flywheel - Stock Resurfaced RB25 Flywheel - (Taken To Local Shop)Steel Braided Slave Cylinder Line - (Sr20store.Com)Braille Auto Compact Lightweight Battery - (Brailleautodevelopment.Com)STOCK S14 Radiator (Milano Motorsports)High Pressure Fuel Injection Hose (Local Autoparts Store)Z32 Fuel Filter - (Purchase From Any General Auto Parts Store)Walbro Fuel Pump - (Phase2Motortrend.Com)S14 Throttle Cable - (Rhddesign.Com)Fuse Box Bracket - (Custom)
