Hoffman5982 wrote: I wasn't calling you out man. That was aimed at Outtowin. He's never owned any godspeed products other than a sway bar, so he has no right of talking trash about their arms. If you've had them and ahd bad experiences, well then you have every right. The OP wants people that have had experience with these products to give their opinions, so you should definitely voice yours since you've had bad experience. Outtowin, on the other hand, is coming in here like he does on every thread that mentions Godspeed or ISIS talking out of his a** because he reads the threads about people that have had problems, most of which probably took their to the track or out street drifting, hit a curb or something, and got all butt hurt when they broke. What Im trying to defend here is that for DD they should be fine. I've had no problems. I really don't know if I'd be comfortable or not taking them out to a track and beating them to death. I don't live anywhere near a track so I don't have to worry about making that decision any time soon
Godspeed RUCAS - not so bad, but I was not impressed with the welds or the material. I sand blasted the arms and they looked like hell. Penetrations in the welds, stress marks in the steel. We re-welded these and added better gussets and they are actually on my car.
Godspeed sway bars - Now they are awesome, but the end welds were also horrible. They weren't complete, they were pitted, and they did not line up. So they were heated and bent about 1/2 inch, blasted, welds ground out and tig welded. Now I don't have an issue (but its only solid metal)
Godspeed Tension rods - Looked much better then other products, but withing 100 miles the boots for the arms were cracked and torn and the set nuts were coming loose. I took them off to check them out and the heim joint is sloppy as can be, I could put them back on and just lock tite them at alignment.Now, but that heim joint sees a ton of force, and I dont trust it.
NOW HOFFMAN, i suggest you change your tone. Your calling me out, on really false presences here and well your entire argument make you look silly. Did you not read I have tried their products? I bash them because I HAVE A REASON TO. Much like I will slam Mishimotos JUNK. So dont call me out like I am some rich guy who can just spend money on whatever I want because it's not true at all. Based on all of what you say you have one used one cheap arm and you think they are awesome because they let you fix your camber situation. Which is awesome, but until you work with their other arms and see what they do don't go calling me out. As for OEM arms they are great if your geometry does not change, they don't move, they don't turn, and the bushings last 15+ years. I have been doing this a while and this is not my first rodeo. You get what you pay for. Now cheaper companies that make quality parts come along all the time, but we are talking about the cheapest of the cheap who is copying the copiers. Godspeed is junk, Isis and Godspeed are manufactured by the same company using the same materials and processes.
As for on topic. You can go with a cheaper RUCA, Cheaper Sway Bar, and a Cheaper Traction rod. But don't skimp on tension or toe rods. They see the most stress and you want those be of quality construction and joints. Depending on how low your going to go you may not need to replace the tension or toe rods. As for ball joints I went with new lower arms over ball joints. They came at a huge discount from my buddies shop supplier (OE style). My rear LCA's were blasted, were pushed out the joints and replaced with MOOG LBJ for a Nissan Sentra. I also added a support plate to the bottom of these.
