Suspension needs for aftermarket
BOBCAT
Car: 2000 Maxima, 94 SER
If i get aftermarket suspention for my car, what will i need?If i go with shocks struts or if i go with coilovers. I need to know what all i need before i buy because i am about to spend some cash.
Help Please!!!!11!
maxhopper
Car: 02 Maxima SE 6spd
You should be able to reuse your factory hardware. You may want to go ahead and replace the front strut bearings while you have everything out.
Edit: You also need to check if your new struts/shocks come with boots.
BOBCAT
maxhopper97 wrote:You should be able to reuse your factory hardware. You may want to go ahead and replace the front strut bearings while you have everything out.
Autozone i am guessing i should get this from?
maxhopper
I got OEM. But I imagine AZ or PB sells them.
BOBCAT
Well. I was needing to know a little more basic information. I was wanting to know if i get coilovers, what else would i need with that? I know that some people have problems with there car after some aftermarket parts are installed and they end up needing one other thing.
maxhopper
When I helped Fezzik install his coil overs, I'm pretty sure it included everything. We did have to reuse the factory bump stops for the rear coils (and cut them in half), but I'm pretty sure that was it. You'll need a spring compressor to take the factory assemblies apart, but you can rent that at AZ.
BOBCAT
OK, well i think i am going with the tokico illuminas. Now I am needing to know which springs to choose.
maxhopper
I have Tein H-techs with my Illuminas. You can look here for more combinations. zerothread/233308
BOBCAT
Bought the suspention Monday.
H&R Springs W/ Tokico Illuminas
I heard on the .ORG that they are very good springs so we will see. I was going to go for the S Techs but i didnt know if i wanted it that low even thought it would have been pretty sweet looking, I didnt want it to jar my fillings out of my head.
BOBCAT
I called the dealership and those stupid things are 37 dollars a piece.
maxhopper
Check post #3 in this thread. zerothread/56283 I got mine at PB's, can't remember what they cost.
lightsout
Car: 00 Nismo Maxima SE
take pix as you work on your car! BEFORE AND AFTER PIX Rock on with the Illumina's, ive got them in the back and LOVE them!! the Blues reside under the front end
BOBCAT
lightsout wrote:take pix as you work on your car! BEFORE AND AFTER PIX Rock on with the Illumina's, ive got them in the back and LOVE them!! the Blues reside under the front end
Why did you get Blues for the front? Funds?
BOBCAT
maxhopper97 wrote:Check post #3 in this thread. zerothread/56283 I got mine at PB's, can't remember what they cost.
The bearings are a little expensive. But i guess if you can only get them from dealer than your F'ed in the A.
I paid about 10 dollars more for the boots so that wasnt a big deal.
