Suspension help.
Son of Dat
Car: 1989 240sx Coupe
Before I ask...Let it be known that I did search, but didn't find very much info.So:
I'm ordering a set of Stance's for Christmas. What else is recommended that I install with them. Ruca's? I figured while I was in there I should make sure everything is prepared to take the abuse of the new setup.
Just the basics, I'm not looking to get super crazy with it. Its a project and I'm not rich by any means...
Thank you.
Son of Dat
Bump, anyone??
adrianfromthecastle
Car: 1992 Nissan 240sx
if you want... rucas to correct camber in rear, inner and outer tie rods to correct caster up front.
nismofly
Car: 89 Nissan 240SX Hatch
get at least ruca's, rear camber will be your biggest alignment issue after a lowering, if youve got more to spend get more multilink stuff
tension rods, tie rods, rear toe and traction rods would be your next step after ruca's
heres a link thatll help a little
zerothread/286065
