Thanks its daytona blue from the 08 350z's.FinkenS14 wrote:Try cutting it?
BTW, love the color
FinkenS14 wrote:Solution for tire rubbage.
Slam the s*** on coilovers, itll make your camber negative enuff, that fixes your problem :P
Your grinder sucks thenBlue.s13 wrote:Thanks its daytona blue from the 08 350z's.FinkenS14 wrote:Try cutting it?
BTW, love the color
Cut it with what? I tried using a tiny little grinder thing but didn't do much
\Sugar wrote:The lip is not made of bondo... if it were you would have broken while trying to hammer it.
You know what needs to be done. Do it or continue rubbing.Blue.s13 wrote:\Sugar wrote:The lip is not made of bondo... if it were you would have broken while trying to hammer it.
I know that the lip is bondo because I hit up all the metal already and when I hit the bondo with the hammer I barely hit it and thats why it didn't crack.
I've already watched that video like 4 times.. I could prolly do the fender lip roll on my driver side quarter panel because its all factory
omgshawn wrote:I would say get it fixed right and it wouldn't be an issue
