susp. lowering and tire size..
livinglegend2100
gettin rims soon, debating on whether to get 17's or 18's. but i also want to lower the car 1"- 2" or somewhere in between. my question would be, (on a 93 s13 hatch) how far can i lower the car with 17 and 18 inch rims without rubbing the wheelwells on every bump???
thanks in advanceNick
ILoveMyRHS13
Car: 1990 Nissan 240sx (Hatch)
zerosearch+http://forums.nicoclub.com/z ... id=140=Win.
Modified by ILoveMyRHS13 at 1:49 AM 2/15/2008
tramp_drift240
Car: 1992 240sx SE Coupe
^ pointless post, RHS13
This thread should be in the wheels and suspension forum, BUT:
as long as youre running the correct size tire, you should be able to lower it as much as youd be able to on stock wheels without danger of rubbing.
I'd suggest 17's as opposed to 18's in your case, and you should still be able to lower your car 2-3 inches without it rubbing ridiculously when you drive.
my 2 cents.
ILoveMyRHS13
Not really. It points him in the right direction.
tramp_drift240
A+B=Win?
i dont see that pointing anywhere but to Failtown.
/thread
ILoveMyRHS13
Click the A and B.
livinglegend2100
yea sorry bout the placement i was kind of in a hurry... idk if a mod can move it or something..
but yea im thinking im gonna go with 17's. unless the right pair of 18's comes along for the right price..
also, if i go with about 8 or 8.5 wide will i have any issues with the fronts hitting when i turn?
tramp_drift240
^ you should be fine up to 9 in the front, 10 or 11 in the back as long as you roll/pull your fenders to accomodate the width.
and RHS13, very sneaky of you.
livinglegend2100
just noticed A and B were links.. thanks rhs13.
but i dont think im gonna run a 10 or 11 on rear thats a little excessive than what i need. i was thinkin 8.5 front and 9-9.5 rear.
ive also hear that when i lower the susp. it messes with the camber. this true?
matthew1302
Car: 90 240sx 3dr
the size is really up to u. cuz generally people roll a little bigger tire on a 17 than they do on an 18 which makes no difference in rubbing. u just have to go with the correct width and offset.....i would go 18''....especially with a small drop like that...
matthew1302
Car: 90 240sx 3dr
and camber could be affected a little...but take that as it comes...nothing major..
ILoveMyRHS13
Okay, I fixed my original post. Sorry for the confusion.*leaves*
Dano
Car: '05 Nissan Frontier Nismo CC
'95 Nissan 240SX base
ILoveMyRHS13 wrote:zerosearch+http://forums.nicoclub.com/z ... id=140=Win.
Nicely played sir
livinglegend2100
aright. okay, so not to be redundant or anything, i just want to get everything right the first time..
if i go 18, with a 2" drop, ill be able to fit the appropriate tires without rubbing?
Grelaz_R_23
Car: 240sx s13, 04' wrx STi
yea word im debating for 2 or 3 inches cuz i got 18s on mines, im thinking 3 and hopefully the worse will be a little fender rolling
livinglegend2100
^ yea it looks like you could get away with a 2" without problems.
how wide are your wheels and what size are the tires??
Grelaz_R_23
from what i believe the rims are actually only 18x7, the tires 235/40 in the rear, 215/35 in the front but thats only cuz 40 wouldnt fit in the front b/c of interference w/ the spring but its stock so yea, but im pretty sure ill get away with it your right
Grelaz_R_23
7.5 actually sorry
kornaz
Car: 95 240sx SE.
Offset?
Grelaz_R_23
4x114
kornaz
Car: 95 240sx SE.
Grelaz_R_23 wrote:4x114
Sorry. I directed the question to the original poster.
And 4X114.3 is the bolt pattern. Offset is this:
Your's is probably 40ish.
livinglegend2100
kornaz wrote:Offset?
maybe a little. i dont want to have to pull/roll the fenders if i dont have too. ide like a nice flush fit
hbpignosePA
Car: 90 240sx hatch (Jackstand Queen)
78 Datsun 280Z (RIP)
89 Toyota Cressida (Sold)
86 Nissan 200SX hatch (sold)
83 Nissan 280ZX turbo (parts car)
90 Volvo 240 (sold)
80 Toyota Cressida MX32 (new daily)
imho... 18s are too big for an s13....
some people have pulled it off, but they didnt cheap out on wheels and suspension either, i think 17s look alot better
on the other note... ur almost going to have to pull your fenders for anything over 8 inches wide, lower offsets will make it flush, but w that wide of a wheel u would be ok with probably around +25
InfinitiAndre
Car: 1997.5 Infiniti J30
hbpignosePA wrote:imho... 18s are too big for an s13....
That brings me to an important simple question. I lowered my 240SX S13 Coupe 1.8 Inches all around. If I got rims the size of 225/40/18 would they rub or hit a fender during bumps? Besides a bumpier ride, what else should I consider?
ZX88
Car: s13
you need to invest in some coilovers cause a 240 with 1-2" drop is still mad 4x4 with the coilovers you dont have to worry about blowing your shocks. Any drop more than 1.5 will most likely lead to a blown shock. with the coil overs you can adjust the drop to fit your wheels. 18s on an s13 without coilovers looks retarted.
PapaBurgundy
Car: 1991 240SX coupe SE CA18DET. 99 Dodge 2500 Cummins TURBO DIESEL 5spd.
18s are a bit much on a s13, decent on an s14 imo. I hope youre not worried about weight, rotating mass has way more effect on your car than body weight even if it is just a few extra pounds. Lower your car two inches and your gonna run out of rear camber adjustment, not cool with the price of 18" tires.
livinglegend2100
yea coilovers are on the list. im working on a pretty tight budget right now.. i want the adjustability of the coilovers as opposed to drop springs
idahotuner
Car: 2012 Dodge Ram 2500 6.7 Cummins
93 Nissan Sileighty
93 Honda Civic hatch
2011 Polaris Ranger
right now i have esplier lowering springs. i think it is a 3 inch drop in the front and 2.5 in the back. i ran 18's with 215-35sit need to go a little bit lower and still. but it never rubbed.
tramp_drift240
^ ive never heard of springs lowering a 240 that much.
but props on the find.
GET COILS.
EVERYBODY, GET COILS.
idahotuner
93 Nissan Sileighty
2011 Polaris Ranger
^ oh i am getting PBM coilovers and RUCAS
this is a link ot the lowering springs i have. ok so thye dont lower it as much as i thought i read the spring rate as the drop lol. so thye lower between 50mm front and 30 in the backhttp://www.sr20shop.com/product.php?productid=188
