Mad_Man wrote:So I just finished installing an m62 supercharger from a Frontier/Xterra into my s13. This wasn't from a Knight kit, but the design is similar. I'll pprobably make a more detailed post about it when everything if perfect. Mechanically, everything works great, but I am having what I believe to be an ignition problem. To start, its running 8psi of boost controlled by a manual controller and that is supported by 480cc injectors, 255lph Walbro fuel pump and an SAFC-NEO. On the dyno we retarted the base timing until we couldn't hear any pinging. Essentially, the afr is pretty steady up until 3500 rpms where it all goes to hell. I think whats happening here is that the spark is being blown out. The NGK iridium plugs are all gapped to ~28 or so, but I dont think they are getting enough power. I plan on getting an msd coil to help, but do you think it could be problems with the distributor/related parts? The dyno tuner also recommended I get some form of timing control, since I need base timing retarted to help low down I need to put it back in at higher rpm. He says that an MSD BTM wouldn't be useful for what I need, since the boost level stays constant for all but the end of the graph I have. What I'm looking for is an ignition that I can program a timing map for, any suggestions? The best I have found so far is the MSD 8979 MSD Multi-Function Ignition Controller, programmable from a laptop.
Anways, here is the dyno run. Since there was the obvious AFR problem starting around 35-3800, we only ran it to 5000rpm.
There are a few things wrong with this whole deal, and I'm just gonna start from the top.
First of all, I'd say you're not blowing out the spark, you're just running ridiculously rich from about 3500 on. When the spark blows out, it shows as a lean spike, not a rich spike. Remember, the AFR's are monitored via wideband O2 sensor, so you if the spark is gone, regardless of fuel content in the cylinder, the O2 reading will be lean, since none was burned and the amount of oxygen is abundant.
Additionally, the lower rpm areas could also use some smoothing.
Secondly, how did you go about pulling the base timing? Did you go through the steps detailed in the FSM, or did you simply just crank the distributor without going through these steps? If you did the latter, then there's a pretty solid chance that your timing is now all jacked up (I did this when I very first turbocharged my KA, 2 yrs ago...).
I agree that a BTM might not be the best option here. I'd say you need to look into things such as:
MegaSquirt 2 ver. 3.0Daughterboard installed in the stock ECU (EEPROM programming)AEM EMS full standaloneHaltechF.A.S.T.MoTec
and any other standalone system you could find.
I currently use a daughterboard setup on my S13, but I'm soon to upgrade to a MS2 (MegaSquirt).
Oh yeah, lose the iridium plugs. Go with NGK plug: BKR6E gapped to abou .030" and don't use the BKR6E-11 because the -11 tag means the ground strap is indexed higher from the electrode to accomodate .044" gapping. This prevents the strap from being parallel to the electrode when you squeeze it down to .030"
The stock coil should be just fine for the boost you're running. Many people make 400whp on the stock coil.
