Mad_Man »
https://forums.nicoclub.com/mad-man-u38440.html
Sun Mar 11, 2007 12:12 pm
Update:
I've upgraded the ignition system so I have powerful spark and adjustability on a laptop. Preliminary timing map I made didn't really change much except immediately better idle, but thats not the issue at the moment.
So after checking the ecu codes on a hunch i saw a code 21 and a code 34. The 21 is easily explained because I had a wire disconnected when cranking the engine over while installing the MSD ignition. Since it stays for 50 or so starts, that code shouldn't show up again. The interesting part is the code 34. As you probably know this is for the knock sensor circuit. Per the FSM i measured continuity to the engine block through the sensor and it read 550k ohms or so. This reading is consistent with sensors cracked due to heat, and upon removal it was indeed cracked.
What I am getting at is, could this malfunctioning sensor be causing most of my timing issues? It would make sense considering the ECU retards timing and bumps up the fuel when a sensor goes bad.
Anyway, what do you guys think?
Modified by Mad_Man at 6:11 PM 3/11/2007
